Carina rear end questiom
08-28-2008, 02:44 PM
Hellod!!!
Anyone knows if the toyota carina st (ta40) rear axle is the same as the toyota ae86, or if the lsd of a ae86 will fit the diff??. Has the carins diff disc brakes??
Thanks
Always on top always on sideways
http://img512.imageshack.us/img512/6080/...tomrx5.jpg
09-03-2008, 05:38 AM
If not, I heard that the AE86, rear end can be used on the Carina.
1987 328ci SR20DET Drift Car
2002 Corolla CE Daily Driver
http://www.TheTunerSource.com
09-04-2008, 04:31 PM
Axle should be the same since ta40 axle is the same as ta60 axle, but it uses drum breaks. However I think the mounting points are different. Perhaps you can ask Brawnie: he just sold his AE86 with Carina axle.
[Image: AEU86 AE86 - Carina rear end questiom]
09-04-2008, 04:54 PM
Zenki AE86 diffs wil fit the TA12/TA22/TA40/TA60 solid rear ends, but you need to take off 6mm of the halfshafts to get it to accept an LSD Smile
09-04-2008, 10:32 PM
The Doctor Wrote:Zenki AE86 diffs wil fit the TA12/TA22/TA40/TA60 solid rear ends, but you need to take off 6mm of the halfshafts to get it to accept an LSD Smile
That's good info! Thumbs up!
Anyone got a zenki diff lying around for me somewhere? Wave
09-05-2008, 09:03 PM
problem solved many Respect! Respect! thanks
04-15-2011, 02:57 PM
Sorry for reviving dead thread, but I was just wondering if this is dead certain before I go nuts with 4age/2tg build, T50 tranny, dw coilovers and equip a zenki ae86 lsd and rear ae86 brakes+pedal box w/adjustable bias, spacers and the whole package for my TA40 wagon: a Zenki ae86 LSD of ANY brand (TRD, Tomei, Kaaz, etc) will definitely fit solid TA40 rear axle? Or did Topic Starter find a different solution?
Regards
R21
1x TA60 82' Sedan 2T 8V
04-16-2011, 08:11 PM
Yes , any zenki will fit, you can doublecheck the VIN-tag on the firewall, look at Trans/axle it should say T50 T(3 numbers) The "T" is telling you it will fit and the number will tell you the ration and that its an open diff!
Remember that if you use a Toyota diff the axles need to be shortened, this might also apply to other brands...
1979 Toyota Corolla KE35
1983 Toyota Corolla AE86
1985 Toyota Corolla AE86
05-08-2011, 04:06 PM
Ah ok, it`s a T312 axle. (T40 transmission)
I`ll get a zenki TRD ae86 LSD then.
Might also have to look at getting discs rear, the right rear drum is shot Sad
Thanks for a conclusive answer!
  Carina TA63 GT-TR - Suspension?? danny 86 11 11,265 01-30-2021 03:39 PM
Last Post: danny 86
  Carina drivers! - Coilovers for a TA60/62 nyberrg 2 7,592 06-05-2017 10:03 AM
Last Post: nyberrg
  20v mains & big end bearing izanagi 9 12,600 12-26-2016 12:42 PM
Last Post: pack
  TA60/TA62 Carina; what fits? nyberrg 10 18,881 10-12-2016 12:57 PM
Last Post: The Doctor
  Ta60 carina steering upgrade? Allexz 15 18,937 06-01-2016 08:12 AM
Last Post: Allexz
