Cams for a stock 4age 16v
08-13-2008, 07:06 PM
AE86_Z Wrote:Conclusion:What do you think about 264 lift 8.1 or 264 lift 7,9? i have a bottom end of 4agze (smallport) and i want to use it like N/A. i ll change the pistons with the pistons of 100kw to increase the compression. The rest ll be stock (bigport head (tvis), ecu, oil pump ect). But i would like the car be streetable not race. **COROLLA EE80 - 4AGE 124HP** |
08-13-2008, 08:20 PM
tolisspi Wrote:Do you have a dyno about horsepower 135-140hp? I think that its a lot for that set up. I don't have any dyno result yet. But I think the 135-140 range not a lot for my previous setup . Don't forget about the TRD 4-1 header, the tuned head, and the raised compression etc. The basic engine could do 124hp. pls watch one of my older vids, I think it's more than 10 extra hp If the dyno will measure less than 140 on friday I will burn my car http://ae86.blog.hu - closed 2006 Toyota Corolla Verso 2.2 D4-D 1992 JDM Nissan Silvia PS13 RB26DETT powered |
08-13-2008, 08:28 PM
tolisspi Wrote:What do you think about 264 lift 8.1 or 264 lift 7,9? i have a bottom end of 4agze (smallport) and i want to use it like N/A. i ll change the pistons with the pistons of 100kw to increase the compression. The rest ll be stock (bigport head (tvis), ecu, oil pump ect). But i would like the car be streetable not race. I think the best choice for a nearly stock engine is 264 8,1 /256 8,0 combination (If you want HKS cams).With this combo engine can reach peak power at ~6800. http://ae86.blog.hu - closed 2006 Toyota Corolla Verso 2.2 D4-D 1992 JDM Nissan Silvia PS13 RB26DETT powered |
08-13-2008, 09:00 PM
I forgot to tell you that i have adjust cam gear TODA.
It isnt good in/ex with 264 8,1? Maybe i ll buy and a standalone ecu to have idle normally. Thanks a lot ... **COROLLA EE80 - 4AGE 124HP** |
08-13-2008, 09:27 PM
tolisspi Wrote:I forgot to tell you that i have adjust cam gear TODA. If you have adjustable camshaft gears, you can tune the peak power, maybe 264/264 ok for you without any standalone. I think a greddy e-manage blue more than enough for that config. But I advice you to tune the header/exhaust system and intake too, before you buy cams. Regards, Z http://ae86.blog.hu - closed 2006 Toyota Corolla Verso 2.2 D4-D 1992 JDM Nissan Silvia PS13 RB26DETT powered |
08-13-2008, 11:28 PM
I have OEM/genuine header/exhaust. I have the super flow HKS for intake.
08-13-2008, 11:31 PM
The best and easiest power gain, if you can buy a really good 4-1 header with free flow exhaust system.
08-14-2008, 12:57 AM
What do you thinck guys about this combo:
264 in ang 256 ex with 8.1 lift? Thanck you. SR Team BURN THE RUBER NOT YOUR SOUL! |
08-14-2008, 01:01 AM
this is my engine running:
81.5 mm pistons standard head gasket worked ports and valves (also combustion chamber) catcams last standard valve cam. 264 252 8.5 and 9mm lift I am running 134.8 WHP and 150 NM This is measured on the wheels. So anything is possible. Cars: "99 Lexus IS200 "86 AE86 Kouki Panda Levin GT-Apex (restore project) "84 AE86 Zenki Blue Levin (project racer) Motorcycles: "02 Yamaha R1 "02 Honda Hornet S "08 BMW R1200GS |
08-14-2008, 08:17 AM
I think the power is from the pistons 81.5 and the cams.
Good diagram without big and anormal curves **COROLLA EE80 - 4AGE 124HP** |
Digital speedometer on stock dashboard | FanIsHere | 0 | 973 |
82mm Stock compression Pistons | apardal | 4 | 2,252 |
Cusco Powerball Headers on a NA 4AGE 16V? | JDMitch | 11 | 19,053 |
05-01-2021 10:09 PM Last Post: Ivan141 |
4AGE 16V engine overheat when at high speed | chenfon | 32 | 18,378 |
4age 16v running roughly - diagnostics shows unknown code | Ryo | 8 | 6,046 |
