will these wheels fit?
01-05-2010, 10:59 AM
like the tittle says,are they gonna fit on my ae86?the car is droped about +/-3cm now
tyre:195/50/15 Size: 15" x 7" 4 Lugs 4 Holes (PCD 4x114.3) +40mm Offset 73 Center Bore Yaris 1.3 xp9 Yaris 1.0 p1 Mercedes citan weekend driver 1985 AE86 |
01-05-2010, 11:07 AM
will not fit..
you will need 20mm spacers on each side to make it fit 5/2018 BMW F22 Coupe 1/1985 Toyota AE86 Levin Coupe |
01-05-2010, 11:17 AM
ok then i know what i must do
thanx Yaris 1.3 xp9 Yaris 1.0 p1 Mercedes citan weekend driver 1985 AE86 |
01-05-2010, 11:27 AM
which offsets will fit then wiht a 15/7 rim?
01-05-2010, 03:01 PM
15x7: between +20 and -12 (stock arches)
with a positive offset the wheels will be deeper in the arches, so closer to the struts. I drove with a 15x7 offset +20 and 195x50/15 and it was about the minimum millimeters from the coilovers on my struts. A negative offset will push the wheels further out of the arches, so if you would mount a -12 offset, you would have the flushed look. Wheels almost in line with the outer fenders. Cool for looks but i would not recommend it when you choosing 15x7. If you stick to the idea of a 15x7, then i would search for a wheel close to offset 0. 5/2018 BMW F22 Coupe 1/1985 Toyota AE86 Levin Coupe |
01-05-2010, 07:54 PM
i had my eyes on these rims but it is just to much offset
http://cgi.ebay.com/ebaymotors/15-EVOKE-...ccessories Yaris 1.3 xp9 Yaris 1.0 p1 Mercedes citan weekend driver 1985 AE86 |
01-06-2010, 12:38 AM
Roger Wrote:i had my eyes on these rims but it is just to much offset these wheels were available with 0 offset earlier. look after some shops, someone must have old stock of them |
01-06-2010, 03:50 AM
look for rota or drag they both have 15x7 et0
I'm so JDM I put everything sideways. AE86 owner |
01-06-2010, 10:29 AM
problem is that those wheels are in 4x100, not in 4x114.3. Drag has them still available in low offset, but then you have to use a wheeladapter.
01-06-2010, 03:38 PM
| Mistlamps don't fit | gh0st | 1 | 3,100 |
10-14-2021 09:00 PM Last Post: banpei |
| Can you identify this wheels? Will they fit AE86? | Ryo | 8 | 13,079 |
| Ae86 bulk head mod to fit hydrolic clutch? | dinkers542 | 8 | 11,870 |
11-25-2014 09:21 PM Last Post: dinkers542 |
| Are these modded TRD N2 flares? | 4000GT | 6 | 20,090 |
06-21-2014 12:16 AM Last Post: 4000GT |
| What injectors are these? | Alex170984 | 4 | 6,818 |
08-05-2013 11:53 AM Last Post: jondee86 |
