which piston is this?
06-27-2014, 11:21 AM
Which piston is this?(smallport?)
Found it together with a 40mm crankshaft in a blacktop ![]()
06-27-2014, 01:06 PM
i think its from big port
pistons pin 18 crack 40 = big port blue or red valve cap pistons pin 20 crack 42 = small port only red valve cap v same is 4agze supercharger 2 gen 3 gen not 1 gen is the same with big port thats i know i hopre hepl u |
06-27-2014, 01:17 PM
(This post was last modified: 06-27-2014 01:17 PM by ditn.)
thanks for info
![]() Forgot to add some extra info. the pin is 20 the crank is 40 100% sure So maybe late bigport or i mismeasured the pin But how can this be in a blacktop 4age? thats the mystery i dont understand |
06-27-2014, 04:14 PM
Not a genuine Toyota 16V piston, maybe Honda?
Sent from my Nexus 4 using Tapatalk AE86 ex-daily |
06-27-2014, 10:23 PM
Hm this is getting weirder and weirder
Aftermarket not possible? How can honda pistons work with a blacktop? |
06-27-2014, 10:46 PM
(06-27-2014 10:23 PM)ditn Wrote: [ -> ]Hm this is getting weirder and weirderI never exactly looked into it but apparently there's a compatible piston from Honda with almost the same specs. Sent from my Nexus 4 using Tapatalk AE86 ex-daily |
06-27-2014, 11:34 PM
(This post was last modified: 06-27-2014 11:54 PM by zenki.)
4afe with the same piston
![]() ハチロク
06-30-2014, 10:38 PM
aha ok thanks.
Is a 4afe crank usuable in a 4age? |
07-01-2014, 03:33 AM
Yep, its a 4AFE piston, unfortunatly they are pressfit wristpin like the bluetop engine. They are low comp so maybe someone was trying to build a turbo engine?
Crank can be used, only downside whould be the 6bolt crank unstead of 8 bolt on 4AGE´s. 1979 Toyota Corolla KE35 1983 Toyota Corolla AE86 1985 Toyota Corolla AE86 |
07-04-2014, 02:09 PM
(07-01-2014 03:33 AM)fax0815 Wrote: [ -> ]Yep, its a 4AFE piston, unfortunatly they are pressfit wristpin like the bluetop engine. They are low comp so maybe someone was trying to build a turbo engine? ok thanks for the answer Hm maybe its weird. Hm unless im mistaken the crank actually was 8 bolts since it was a blacktop flywheel need to check |
| 20v BT - which oil pump? | Mylesmck | 4 | 6,182 |
| Piston ID | kazi | 5 | 8,849 |
08-11-2019 03:34 PM Last Post: totta Crolla |
| 86mm piston wizards... | fantapants | 6 | 9,649 |
05-30-2017 02:36 PM Last Post: jdm86gtz |
| Rim width. Which is best.... | Dino86 | 5 | 10,219 |
| Piston Identification | Alex170984 | 3 | 7,848 |
05-17-2016 12:47 PM Last Post: Alex170984 |
![AEU86 AE86 - which piston is this? [Image: AEU86 AE86 - which piston is this?]](http://www.ae86.be/12/153.jpg)
![AEU86 AE86 - which piston is this? [Image: AEU86 AE86 - which piston is this?]](http://i129.photobucket.com/albums/p229/shaneoex/DSC02080.jpg)
