what bearings for my build?
09-22-2012, 11:24 AM
Hello everyone,
I'd like o get some input/experiences regarding bearings for mains and rods for my engine build.
I'm using a 40mm crank so less options available Sad
So far I considered TRD and ACL Race for the Mains (100$-130$)
and TRD for the rods.
My engine will rev up to 8-9k and 170-200hp @fly.
Thanks for reading and looking forward to your experiences.
PS: also opinions about the 'perfect' clearance/tolerance for the bearings would be interesting. Car is not an all out racer so still used on the street for a run down to the shops etc...
09-22-2012, 03:41 PM
You also have Clevite (Mahle) available in 40mm Wink
09-22-2012, 03:46 PM
Project D Wrote:You also have Clevite (Mahle) available in 40mm Wink
There are quite a few other brands (clevite, F1 Black, OEM Toyota, etc). I'm looking for experience people had with any and how they lasted etc... As I don't plan to drop the sump every 6 months to check if everything is still in one piece.
09-22-2012, 04:53 PM
I'm running clevite if that helps...........
Oh... btw... you DON'T want to spin that crank much above 8400....
the early cranks are lighter... by almost a kilo... but because SOME of the counter weights are different, the crank can have issues above the mid 8000s
Dan -
09-22-2012, 05:12 PM
oldeskewltoy Wrote:I'm running clevite if that helps...........
The crank will be worked to prevent this. I won't take it beyond 7k in this country anyway.
How much were the Clevite and are they available in different sizes?
ACL only has 2 sizes. TRD 2 seizes for rod-end and 6 for mains. And so on...
09-22-2012, 10:25 PM
Sorry... can't tell you that, I didn't do the bottom end, Loynings did....
Dan -
  7AGE Build apardal 5 3,066 08-02-2024 12:11 PM
Last Post: apardal
  Question on Rod Bearings mister86 3 5,186 03-19-2020 03:46 AM
  Emergency help find store with bearings france Allexz 5 6,209 09-12-2019 03:24 PM
Last Post: Allexz
  Build your own adjustable fuel pressure regulator ;) oldeskewltoy 8 24,220 08-19-2018 12:08 PM
Last Post: AlexKTM
  Diff bearings izanagi 11 18,514 07-05-2014 07:29 PM
Last Post: assassin10000
