valve tick on cylender two intake
11-28-2014, 12:51 AM
Purchaced a rebuilt 4age for pretty cheap. 500 miles on the rebuild only problem is that is has valve tick on cylender two intake. Has anyone had this problem on their 4age and what did you find was the cause (bad lifters, bent valves, etc.)
I have done bottom end assembly but I have never worked on a top end before so any help is much appreciated! Thanks, Dinkers |
11-28-2014, 03:39 AM
If the compression is good, check the valve clearance. The
valves can tick if the clearance is too great. Cheers... jondee86 |
11-28-2014, 10:45 AM
Ill open it up and check tomorrow. Appreciate the input!
Thanks, Dinkers |
11-28-2014, 06:23 PM
(This post was last modified: 11-28-2014 06:24 PM by oldeskewltoy.)
Clearances.... no tighter than is the first number, no looser than is the second number
Are you absolutely sure its a valve? The injectors make a fair amount of ticking noise.... Dan - You can | OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
11-29-2014, 12:29 AM
Unfortunately I cant tell if its the injectors as I bought the engine by inteslf out of the car.
Is there a special tool to measure the the clearance? |
11-29-2014, 04:39 AM
(11-29-2014 12:29 AM)dinkers542 Wrote: Is there a special tool to measure the the clearance?feeler gauge set Dan - You can | OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
12-02-2014, 09:30 AM
The guy whom I purchaced the engine said when he rebuilt the head he reused the valve springs so maybe they just need to be replaced.
12-02-2014, 12:28 PM
(12-02-2014 09:30 AM)dinkers542 Wrote: The guy whom I purchaced the engine said when he rebuilt the head he reused the valve springs so maybe they just need to be replaced. What valve clearances do have at the moment ? An analogue brain in a digital World |
12-03-2014, 01:41 AM
(This post was last modified: 12-03-2014 01:49 AM by allencr.)
dinkers542 Wrote: Unfortunately I cant tell if its the injectors as I bought the engine by inteslf out of the car. OK! Finally! You've got no idea at all about anything except what a seller told you about a 'valve tick'! Yes, it is possible that a spring/s is broken. This could be anything, anywhere. Check it ASAP, BEFORE starting or turning over or even moving at all. Good luck. So what! |
12-03-2014, 03:19 AM
I havent gotten my feeler guage set in the mail yet so I have not been able to check the clearance yet.
I trust this guy enough to believe his opinion. He is a regular on club4ag and currently has 2 hatches and a coupe running nicely. But I will be careful with it and will tear down the head before installing it in my car. Thanks, Dinkers |
| 4A-GE valve shim disintegrated | DaLanZhu | 2 | 2,378 |
04-30-2025 12:54 PM Last Post: DaLanZhu |
| 4AGE Valve Buckets Scored | Steller Engineering | 2 | 2,474 |
| 20 Valve Blacktop smoking after engine flush - why? | RolanTHUNDER | 2 | 3,625 |
| HKS valve springs | totta Crolla | 3 | 4,159 |
| AE86 4age engine not starts crank ok backfires to air intake | Ryo | 18 | 23,965 |
