valve tick on cylender two intake
11-28-2014, 12:51 AM
Purchaced a rebuilt 4age for pretty cheap. 500 miles on the rebuild only problem is that is has valve tick on cylender two intake. Has anyone had this problem on their 4age and what did you find was the cause (bad lifters, bent valves, etc.)
I have done bottom end assembly but I have never worked on a top end before so any help is much appreciated!
Thanks,
Dinkers
11-28-2014, 03:39 AM
If the compression is good, check the valve clearance. The
valves can tick if the clearance is too great.
Cheers... jondee86
11-28-2014, 10:45 AM
Ill open it up and check tomorrow. Appreciate the input!
Thanks,
Dinkers
11-28-2014, 06:23 PM (This post was last modified: 11-28-2014 06:24 PM by oldeskewltoy.)
Clearances.... no tighter than is the first number, no looser than is the second number
[Image: AEU86 AE86 - valve tick on  cylender two intake]
Are you absolutely sure its a valve? The injectors make a fair amount of ticking noise....
Dan -
11-29-2014, 12:29 AM
Unfortunately I cant tell if its the injectors as I bought the engine by inteslf out of the car.
Is there a special tool to measure the the clearance?
11-29-2014, 04:39 AM
(11-29-2014 12:29 AM)dinkers542 Wrote:  Is there a special tool to measure the the clearance?
feeler gauge set
Dan -
12-02-2014, 09:30 AM
The guy whom I purchaced the engine said when he rebuilt the head he reused the valve springs so maybe they just need to be replaced.
12-02-2014, 12:28 PM
(12-02-2014 09:30 AM)dinkers542 Wrote:  The guy whom I purchaced the engine said when he rebuilt the head he reused the valve springs so maybe they just need to be replaced.
What valve clearances do have at the moment ?
12-03-2014, 01:41 AM (This post was last modified: 12-03-2014 01:49 AM by allencr.)
dinkers542 Wrote:  Unfortunately I cant tell if its the injectors as I bought the engine by inteslf out of the car.
OK! Finally!
You've got no idea at all about anything except what a seller told you about a 'valve tick'!
Yes, it is possible that a spring/s is broken.
This could be anything, anywhere.
Check it ASAP, BEFORE starting or turning over or even moving at all.
Good luck.
So what!
12-03-2014, 03:19 AM
I havent gotten my feeler guage set in the mail yet so I have not been able to check the clearance yet.
I trust this guy enough to believe his opinion. He is a regular on club4ag and currently has 2 hatches and a coupe running nicely. But I will be careful with it and will tear down the head before installing it in my car.
Thanks,
Dinkers
  4A-GE valve shim disintegrated DaLanZhu 2 2,388 04-30-2025 12:54 PM
Last Post: DaLanZhu
  4AGE Valve Buckets Scored Steller Engineering 2 2,485 10-06-2023 05:34 PM
  20 Valve Blacktop smoking after engine flush - why? RolanTHUNDER 2 3,629 11-30-2022 12:09 PM
Last Post: RolanTHUNDER
  HKS valve springs totta Crolla 3 4,166 05-25-2022 10:24 PM
  AE86 4age engine not starts crank ok backfires to air intake Ryo 18 23,971 08-16-2018 01:36 AM
