vacuum reservoir
05-14-2007, 05:38 PM
vacuum reservoir
anyone know where to get one? I think I need to fit a map sensor along with my ITB's
Cheers
Ivan
1972 MG Midget - AE86 Engine, Ford Anglia Axle - Escort LSD - Live the Dream!!1
05-16-2007, 10:03 AM
vacuum reservoir
The MAP sensor needs to be able to respond quickly to changes in
manifold pressure, so there is no need for much volume in the vacuum
"reservoir". It is only necessary to bring a vacuum tapping from each
throttle to a common point. A short length of 10 dia alloy tube with the
ends plugged would do fine. And a "pulsation dampener" in the line to the
MAP sensor would be a good idea as well.
Cheers... jondee86
05-16-2007, 10:53 AM
vacuum reservoir
jondee86, you just described the stock fuel rail Cool
05-16-2007, 03:25 PM
vacuum reservoir
If you are after a vacuum collector/canister so you can still run the brake booster (and map sensor if you are not switching to standalone ECU and mapping purely on throttle position) these guys have what you are looking for.
Golden Eagle Manufacturing
[Image: AEU86 AE86 - vacuum reservoir]
I am using one of these with my ITBS on the F20 engine. Very very cheap considering.
I had a posh trust one on my old 4AGE when running ITBS - but I was daft and sold it LOL.
Regards Ian.
05-16-2007, 11:04 PM
vacuum reservoir
Thanks,
That's exactly what i'm after, I have just ordered one.
Cheers
Ivan
  US-spec vacuum hard lines LordTD 2 6,940 04-27-2015 07:18 PM
Last Post: Project D
  VALVE ASSY, VACUUM SWITCHING, what's this for ? Uzelac 10 19,865 11-22-2013 10:40 PM
Last Post: jondee86
  4AGE 20v ITB vacuum instructions on Intecracing.com JAVResistance 17 41,027 05-07-2011 05:50 AM
Last Post: jondee86
  vacuum reading on idle Bean 6 10,513 10-12-2010 11:28 AM
  Manifold Vacuum on 16V with ITB's... jondee86 7 11,263 04-15-2010 10:57 AM
Last Post: jondee86
