timing tuning problem
08-28-2008, 10:53 AM
Dyno Bench = Chassis Dyno (Rolling Road or Hub Dynomometer) ?
It is usual when testing on a rolling road, to make a series of tests from low rpm to high rpm with WOT. The dyno provides enough resistance to control the rate of increase in engine speed. This allows the monitoring equipment to take reading at certain speeds, for the purposes of creating performance graphs. Under these conditions the engine is operating at maximum load and the ignition advance will be suitable for the WOT AFR. Without any load, if the throttle is snapped wide open, a 4AGE engine will run from idle to redline in one second . This is hardly long enough to take any ignition advance readings... unless you have some fancy electronic equipment ![]() If the timing is set to 30 deg advance at 5500 rpm without load, it will drop to 20 deg or less with load at WOT. Standard timing is >16 deg advance at idle (T and E1 not shorted). You had 7 deg, which shows that it was retarded by at least 10 deg from standard. You would be down on power, and at risk of burning exhaust valves Cheers... jondee86 |
08-28-2008, 10:55 PM
by Dyno bench , I meant rolling road .
I have 7° at idle with Tand E1 shorted , but I forgot to check without jumper if I'm near 16° or not . That's what I'll check . THANKS AND REGARDS Filh Filh Save the RWD cars |
| 20v Silvertop stock ignition timing and fueling maps | Lykowsky | 5 | 19,147 |
| 4agze timing | leon205gti | 11 | 19,740 |
04-07-2017 03:10 AM Last Post: jondee86 |
| Toda timing info - with good general 4AG timing info too | oldeskewltoy | 0 | 7,547 |
| [Tutorial Video] Setting 4A-GE Ignition Timing | Homem Bomba | 0 | 7,630 |
04-21-2014 02:41 PM Last Post: Homem Bomba |
| Ecu ROM tuning | Alex170984 | 4 | 8,181 |
10-13-2013 08:03 AM Last Post: Apsogos |
