the many more 4AGZE questions topic
04-02-2013, 12:40 PM
Post: #31
And a couple more questions Smile
*im a bit in a struggle deciding what i want from brakes for the front,2 options
257mm grooved discs+s13 calipers +ferodo 2500/3000 pads
263 mm grooved disc+rx7 calipers+? pads
(i am concerned about the brake balance,and overdoing it with the brakes)
which one would you chose?
*the seat
im still hitting my head against the cage with everything i tried ...
tried lower seat rails with my sprinter sparco seats
tried home made rails on the lowest possible point using the standard holes for the seats
now im not sure what to do anymore
put them on the floor and buy better seats that are flat?
cut the floor(what about structual parts?),last resort dont want to do this
what did you do?
like this
http://i34.photobucket.com/albums/d145/e...dm3007.jpg
or
this
http://i34.photobucket.com/albums/d145/e...loor-1.jpg
will it mess with structure of the chassis?
04-02-2013, 12:46 PM
Post: #32
Have you thought about getting that RX7 Caliber with Mini Cooper S 276mm Disk conversion bracket. Its exelent, breaking power, and it lines up perfectly. Thumbs up!
Restoring my AE86, all the way... Going JDM style Big Grin
http://www.aeu86.org/viewtopic/ae86/p/150463#150463
04-03-2013, 09:23 PM
Post: #33
y but there are a couple reasons why i dont wanna do that Smile
*im not a big fan of redrilling discs
*278mm is to big.
i want a setup were i dont have to redrill discs Smile
the seats are giving me a headache,since i have shorter legs even if i put the seats at the structure point,i wont be fully able to reach the pedals.
So my only option withouth killing the chassis is moving the pedals.
Is anyone familiar with the pedalboxes from rally?
also finally found some plug courds for the 4AGZE
Levin 4AGZE, KV85 - Magnecor Ignition Lead Kit (4 Lead Set)
is any familiar with this brand?
04-04-2013, 01:35 PM
Post: #34
You only have to re-drill the existing holes in the the disks, so it will take a 12mm bolt, its very easy to do that Smile
04-24-2013, 12:49 PM
Post: #35
i dont like redrilled discs,its probably safe but i wont feel confident drive them Smile
Anyway since i cant find anything and after a long talk with an ae86 grpa driver i decided to make my own kit xd
Will be using ap 4 pots
customs discs from the supplier of ap racing,if i read correct i can use any size/thickness i want 1 piece
and adapters somewhere
proved quality
if anyone else is also interested or has some idea's/improvement let me know Thumbs up!
04-24-2013, 01:35 PM
Post: #36
What I ment. was that you only have to redrill the existing holes in the disk, to a bigger diamenter. Its very easy, and everything lines up perfectly.
The thing that you are planning is a lot more difficult, if you don't get the bracket 100% lined up with the disk and the caliber, it won't brake as good as you had hoped.
04-24-2013, 01:41 PM
Post: #37
I have some suggestions:
Your current thinking about brake setups will change with real power/grip/speed.
For example, I have a stock powered MX5 using stock brakes with Yellowstuff pads. My braking decelleration G's are on par with MX5 cup cars, so she stops nicely on track. No pad fade, no problems whatsoever. I've been on this set of pads for maybe 15 trackdays and 2 years of daily driving. Pads still have life left and discs are OK.
My friends drive MX5 turbo's at approx 250bhp@wheels. They are now in the 1m:52s at Zolder. They can now disintegrate a set of pads and discs in a single day at zolder or other heavy braking circuit. So now other things become important, mostly:
How long do my pads and discs last?
How much does it cost to replace them?
Going custom discs can be a problem on that front, going AP calipers too. If you size the whole thing large enough you should be able to get the discs to last. Going two piece with aluminium hats will shave some weight and save money when you only have to change friction discs. Check beforehand how much real pads will costs and take that into account. Things like Carbone Lorraine.
Which rim size will you be running? 14s or 13s? Be prepared to take a beating on disc replacement if you go 13 and get fast :-)
04-24-2013, 10:25 PM
Post: #38
266-280 mm front ish and 257 mm in the back.
15 inch wheels braid rallyversion
Can you explain what you mean with custom discs and ap calipers on the front can be a problem,too good ?
wont last long?
with custom i mean i can say i want 270mm discs who are 22mm thick
pads ferodo ds2500 probably.
advantage for me is i can do discs and pads/2 because we drive with 2.
@Vaptor really?
so mini cooper s is also 4*114,3 same hub diameter 67,1 i think
and you just need to make the four bolts big bigger?
05-31-2013, 11:35 PM
Post: #39
one more question
which would be the best clutch cover on a 212 mm flywheel
would be used with a stock 4AGZE
i wanted exedy but they dont just sell the clutch cover
  20v Silvertop - New Haltech ECU & Couple of questions 20valver 10 6,808 05-26-2024 07:40 PM
Last Post: totta Crolla
  Windscreen stoopid(?) questions.... Mylesmck 7 3,488 04-30-2024 09:46 PM
Last Post: Mylesmck
  Brake Bias Questions mad.matt 10 14,704 01-03-2019 04:54 AM
  wider rear axle,track width,suspension questions ditn 6 11,694 10-18-2016 11:50 AM
Last Post: fantapants
  Suspension questions leon205gti 17 19,054 04-30-2016 09:26 PM
Last Post: krullibull
