the many more 4AGZE questions topic
02-20-2013, 07:08 PM
Vaptor Wrote:Have planed a 2" piping similer to what you have planned:
[Image: AEU86 AE86 - the many more 4AGZE questions topic]
As a exhaust I am going to use a 4-2-1 equal length 1.65" runners with a 2.5" collector, exhaust piping will be 2.5" with a muffler end 3"
Also head work, with oversize valves, hope for a fun engine Cool
I'd run 3" pipe from the filter to the S/C...
Dan -
02-20-2013, 07:14 PM
here check mine
its working and 180 to 190 hp
http://www.aeu86.org/viewtopic/my-ride/p/154052#154052
sorry for the edit
AE86 owner
02-20-2013, 07:30 PM
@oldeskewltoy
thanks for the prices,i am currently waiting for dp-engineering to answer my mail.Depending on the price i will do the upgrade now or wait until later in the year.And then we can discuss what would be the best option for my head
Thumbs up!
Out of curiosity,how much more do you charge if you have to provide the head itself too?
@NoHachi
interesting point,when i went to zolder this year we somtimes drove for almost 2 hours straight since we never encountered problems Huh
30 minutes -> swap driver -> 30 minutes -> short break -> 30 minutes swap driver ->1 hour brake *2
I will wait for dp-engineering answer and then further research
I wonder how HKS did this with there supercharger kit on a 4AGE.
Did they use another ecu also?
how good would you rate this then(forgive my drawing skills)
red parts are changed.
so if collecting all the info
actually my last piece of the manifold had a dent so i will replace it,perfect moment to get it right.
what would be best 4-2-1 or 4-1,currently i have 4-1
so
3 inch from the filter to the S/C
then 2 inch to the manifold
then 2.5 inch from the header to the back
#|BUDA|
i dont see a picture Sad
02-20-2013, 08:45 PM
AE86 owner
02-21-2013, 01:34 AM
ditn Wrote:@oldeskewltoy
Thumbs up!
Yes... I can supply you with a head... now for the BUT....
Frequently a head needs more than a cleaning, the valves, or guides, or even a valve seat could be bad. Fixing these parts costs extra, over and above the costs I've posted.
By you sending me your head... I'm ASSUMING it is in good condition. If you send me a head not in good condition, then there are added costs to restore the head to good.
IF I sell you a head... the first thing I have to do is to make sure the head is good. I DO have 2 largeport heads I've not yet dismantled, IF either is good, I'd sell one for $125.00 If neither is good, it will cost me more than $125 to make one of them good.
Does any of that make sense?? In essence... yes if I have a good head, I'll sell it for $125.00 If I don't have a good head, it will cost $50 for the bad head... and it could cost as much $300-$400 to make it good.
*IF* you want me to check and see if either is good... I can do that, it'll take me a few days to check and verify.
Dan -
02-21-2013, 11:23 PM
The head looks to be in good shape.
thanks for the info again,now we wait for dp-engineering to answer my mail ...
@|BUDA|
good read,thanks for the link.
so my 4-1 header is 5cm or 2 inch.
is it better to make it 2,5 inch or?
the plan is then
2/2,5 inch header to middle part 2,5 inch to backbox 2,5 inch
02-22-2013, 08:22 AM
oldeskewltoy Wrote:I can supply you with a head... now for the BUT....
Sorry for the hijack, But is there a post somewhere with before&after flow numbers, or a percentage if you don't want give up the numbers? Thumbs up!
I haven't taken look at much of your stuff, kinda gave up after too many polished ex port pics.
02-22-2013, 08:56 AM
Header should also be 2.5", you can proberly just cut the end of your own header so that the hole will become 2.5", and then just weld a 2.5" V-Flange on Smile
Restoring my AE86, all the way... Going JDM style Big Grin
http://www.aeu86.org/viewtopic/ae86/p/150463#150463
02-22-2013, 07:51 PM
I have both... unfortunately my computer crashed.. I'm on my Lapdock 500 (phone based laptop) and I'm not as proficient with it. Both are in my online photos so are publicly viewable.
Pssssst... those numbers were a few years ago... my work has improved since then. I'll be able to tell you more soon... my flowbench should be back up and running very soon
Wink
Dan -
02-22-2013, 09:44 PM
the little red arrows are pointing to 7.1mm lift, or cams from 1988 on ward
the blue arrows are 7.5mm lift from the earlier pre 1988 engines
As the arrows show even with stock cams, my port work improves flow. Btw, those numbers were back in 2009, my exhaust port work has improved since then. Evil
Dan -
  20v Silvertop - New Haltech ECU & Couple of questions 20valver 10 6,109 05-26-2024 07:40 PM
Last Post: totta Crolla
  Windscreen stoopid(?) questions.... Mylesmck 7 3,120 04-30-2024 09:46 PM
Last Post: Mylesmck
  Brake Bias Questions mad.matt 10 14,234 01-03-2019 04:54 AM
  wider rear axle,track width,suspension questions ditn 6 11,305 10-18-2016 11:50 AM
Last Post: fantapants
  Suspension questions leon205gti 17 18,210 04-30-2016 09:26 PM
Last Post: krullibull
