the many more 4AGZE questions topic
03-06-2013, 11:43 AM
<=been in the hospital, so couldnt respond.
looks nice Thumbs up!
Didnt recieve any response from dp engineering so i will search someone else or wait for now.
I found an exhaust system from janspeed but the sice is 58 mm or 2.3 inch,would this also be ok?
03-20-2013, 01:40 PM
another questions
4-2-1 or 4-1 for a 4AGZE?
03-20-2013, 03:34 PM
ditn Wrote:another questions
It depends how you would like your car behave.
If you like to drive only on the low / middle rev and have all the torque / hp there, go for a 4-2-1. (it would be my personnal choice for a gze)
If you want to keep some hp at a higher rev (flattening your curve somehow) go for a 4-1.
But I don't think it will change things a lot, after all the supercharger is prone to override all the other components.
03-20-2013, 05:13 PM
Its not always as simple as that though. If you have a choice between a perfect 4-1 and a perfect 4-2-1 then yes.
But I've seen only 1 4AGE header that comes close.
The quality of the welding, the merges used, the use of correct diameters and lengths of parts, they all make a difference.
A good 4-2-1 will outperform a normal 4-1 by a large margin in top end power.
03-20-2013, 11:25 PM
i have a janspeed 4-1 header for the moment.
So would you say i better go for a 4-2-1 or just stick with what i have.
I saw this header online somewhere its a 4-2-1 from a 4GZE
[Image: AEU86 AE86 - the many more 4AGZE questions topic]
03-21-2013, 01:14 AM
ditn Wrote:i have a janspeed 4-1 header for the moment.
That header APPEARS to be a HKS for LHD
It should be decent for boost, check... I believe the OD of those primaries are 42mm
Dan -
03-21-2013, 08:26 PM
its gone already,guess i will keep my 4-1 for now then and save up for a good 4-2-1 like you say.
gonna buy a 58mm/2,3 inch janspeed system i think,is the closest i can find thats still affordable.
Is there a LHD and RHD janspeed system or is it all the same,dont want to end up with a RHD while my car is LHD Smile
03-21-2013, 08:46 PM
Have you looked at this one?
http://www.ebay.com/itm/181004077932?ssP...1497.l2648
I have bought this one, and its a good build quality, pipes are bend smooth and are equal length. and cheap to Smile
Restoring my AE86, all the way... Going JDM style Big Grin
http://www.aeu86.org/viewtopic/ae86/p/150463#150463
03-28-2013, 10:35 PM
ditn Wrote:<=been in the hospital, so couldnt respond.
do you still need awenser from DP engineering?
I know them personally, worked togheter with Pieter few years ago Smile
I could drive by sometimes.. only 15km away from my home..
Vaptor Wrote:Have you looked at this one?
I am personally not convinced about the quallity? is it OK yes? basic looks OK, but i am not sure if it will last long
regards, Roel
Gtsi-R
"Trust me, I was an engineer"
03-28-2013, 11:28 PM
nah
i dont think i want an answer from them anymore Smile
hm im not to keen about the brand but i will keep it in mind thanks.
  20v Silvertop - New Haltech ECU & Couple of questions 20valver 10 7,664 05-26-2024 07:40 PM
Last Post: totta Crolla
  Windscreen stoopid(?) questions.... Mylesmck 7 4,037 04-30-2024 09:46 PM
Last Post: Mylesmck
  Brake Bias Questions mad.matt 10 15,453 01-03-2019 04:54 AM
  wider rear axle,track width,suspension questions ditn 6 12,243 10-18-2016 11:50 AM
Last Post: fantapants
  Suspension questions leon205gti 17 20,137 04-30-2016 09:26 PM
Last Post: krullibull
