the connector saga (please help everyone)
12-20-2012, 09:21 PM
(This post was last modified: 06-23-2014 12:10 PM by Bean.)
Due to personal need I was on the look for the crimp receptacles for the harness ECU plugs... after I managed to get the part numbers (thanks Project D) I thought why not try to find them all, so here goes - anybody that knows something PLEASE chip in:
Injectors are Bosch EV1 style, as far as I know here are all the TE part numbers for the Nippon Denso 42 (10-18-14) connector (made by Tyco Electronics Japan): Code: 170352-2 PULSE LOCK CRIMP CONTACTS I'll try and keep this first post up to date, any info is welcome
AE86 ex-daily |
12-21-2012, 03:41 PM
If I find anything I will post them here :wink:
12-25-2012, 02:33 PM
Last time I tried getting my hands on the ECU receptacle it proved pretty much impossible in the Netherlands. Back then I worked at a PCB assembly fab and tried to get one through the purchases department. Might be good to check availability as well.
12-27-2012, 08:56 AM
Some general info for all you people (re)building wiring harnesses:
http://www.rbracing-rsr.com/wiring_ecu.html http://www.rbracing-rsr.com/sq6wiringloom.html At least I found them interesting/useful! JapanPower UoP Racing website UoP Racing videos Racing, because football, basketball, tennis & golf only require ONE ball.... |
12-27-2012, 10:56 AM
Bean I know this probably is not much use to you but it may help someone
in the future that does a search. When I went to smallport injectors and I wanted to keep my bigport loom intact I used a selection of these plugs / sockets to make a plug in jumper cable. In my case I used smallport injector pig tails with the male timer plug fitted to the other end to plug into the loom: http://www.ebay.co.uk/sch/m.html?_nkw=ti...workshop27 An analogue brain in a digital World |
12-27-2012, 12:06 PM
This is absolutely fine. The intent of this thread is to accumulate all plug/wiring related things we know, so every bit helps
![]() I'm currently trying to find the plugs (both ends) used on the ignition side of the 4AGE (distributor, igniter etc of all versions). Unfortunately so far I only hit dead ends makes me wish I had kept my spare loom, though it would have been a pity to cut it up. AE86 ex-daily |
06-23-2014, 12:06 PM
10pin ECU plug housing, 18pin ECU plug housing
, ![]() ECU plug housing contacts (50pieces), Injector connectors (BOSCH EV1) ,
AE86 ex-daily |
06-23-2014, 12:56 PM
Wow.... you found them...
06-23-2014, 01:13 PM
(This post was last modified: 06-23-2014 01:14 PM by Bean.)
Did find them a long time ago see top post but couldn't buy them until now as they wouldn't sell to me when I was in Europe (as I'm not a registered business).
Guess you don't need them anymore with the 20V swap (different plugs anyway). Sent from my Nexus 4 using Tapatalk AE86 ex-daily |
| TUV RHD AE86 Germany (help please) | 4dori | 9 | 11,151 |
07-17-2019 07:42 PM Last Post: Hachigo83 |
| Carb question please help | MIGGZFSU | 3 | 6,921 |
03-29-2017 03:06 PM Last Post: MIGGZFSU |
| which connector is this | ditn | 7 | 10,942 |
07-27-2015 11:24 AM Last Post: pack |
| Whining noise HELP PLEASE | izanagi | 10 | 16,926 |
03-26-2015 06:48 PM Last Post: Komba |
| help, puzzled by the radio connector | Bean | 4 | 8,125 |
11-17-2014 11:32 PM Last Post: banpei |
![AEU86 AE86 - the connector saga (please help everyone) [Image: AEU86 AE86 - the connector saga (please help everyone)]](http://i134.photobucket.com/albums/q109/banditbean/Garage/AE86/th_IMG_20140623_124033_zps07zepadh.jpg)
![AEU86 AE86 - the connector saga (please help everyone) [Image: AEU86 AE86 - the connector saga (please help everyone)]](http://i134.photobucket.com/albums/q109/banditbean/Garage/AE86/th_IMG_20140623_124045_zpsq9h2telx.jpg)
![AEU86 AE86 - the connector saga (please help everyone) [Image: AEU86 AE86 - the connector saga (please help everyone)]](http://i134.photobucket.com/albums/q109/banditbean/Garage/AE86/th_IMG_20140623_124056_zpslijx58db.jpg)
![AEU86 AE86 - the connector saga (please help everyone) [Image: AEU86 AE86 - the connector saga (please help everyone)]](http://i134.photobucket.com/albums/q109/banditbean/Garage/AE86/th_IMG_20140623_124300_zps21kapqhf.jpg)
