the connector saga (please help everyone)
12-20-2012, 09:21 PM (This post was last modified: 06-23-2014 12:10 PM by Bean.)
Due to personal need I was on the look for the crimp receptacles for the harness ECU plugs... after I managed to get the part numbers (thanks Project D) I thought why not try to find them all, so here goes - anybody that knows something PLEASE chip in:
Injectors are Bosch EV1 style, as far as I know
here are all the TE part numbers for the Nippon Denso 42 (10-18-14) connector (made by Tyco Electronics Japan):
Code:
    170352-2    PULSE LOCK CRIMP CONTACTS
    172315-7    PULSE LOCK PLUG HSG 10P      YELLOW
    172316-7    PULSE LOCK PLUG HSG 18P      YELLOW
    172354-7    PULSE LOCK PLUG HSG 14P      YELLOW
    1-172489-7 PULSE LOCK CAP  HSG 42P ASSY  YELLOW
last in the list includes the pins that are soldered to the PCB
I'll try and keep this first post up to date, any info is welcome Smile
12-21-2012, 03:41 PM
If I find anything I will post them here :wink:
12-25-2012, 02:33 PM
Last time I tried getting my hands on the ECU receptacle it proved pretty much impossible in the Netherlands. Back then I worked at a PCB assembly fab and tried to get one through the purchases department. Might be good to check availability as well.
12-27-2012, 08:56 AM
Some general info for all you people (re)building wiring harnesses:
http://www.rbracing-rsr.com/wiring_ecu.html
http://www.rbracing-rsr.com/sq6wiringloom.html
At least I found them interesting/useful!
JapanPower
UoP Racing website
UoP Racing videos
12-27-2012, 10:56 AM
Bean I know this probably is not much use to you but it may help someone
in the future that does a search.
When I went to smallport injectors and I wanted to keep my bigport
loom intact I used a selection of these plugs / sockets to make a
plug in jumper cable.
In my case I used smallport injector pig tails with the male timer plug
fitted to the other end to plug into the loom:
http://www.ebay.co.uk/sch/m.html?_nkw=ti...workshop27
12-27-2012, 12:06 PM
This is absolutely fine. The intent of this thread is to accumulate all plug/wiring related things we know, so every bit helps Smile
I'm currently trying to find the plugs (both ends) used on the ignition side of the 4AGE (distributor, igniter etc of all versions). Unfortunately so far I only hit dead ends Sad
makes me wish I had kept my spare loom, though it would have been a pity to cut it up.
06-23-2014, 12:06 PM
10pin ECU plug housing, 18pin ECU plug housing
[Image: AEU86 AE86 - the connector saga (please help everyone)], [Image: AEU86 AE86 - the connector saga (please help everyone)]
ECU plug housing contacts (50pieces), Injector connectors (BOSCH EV1)
06-23-2014, 12:56 PM
Wow.... you found them...
06-23-2014, 01:13 PM (This post was last modified: 06-23-2014 01:14 PM by Bean.)
Did find them a long time ago see top post but couldn't buy them until now as they wouldn't sell to me when I was in Europe (as I'm not a registered business).
Guess you don't need them anymore with the 20V swap (different plugs anyway).
Sent from my Nexus 4 using Tapatalk
  TUV RHD AE86 Germany (help please) 4dori 9 7,757 07-17-2019 07:42 PM
Last Post: Hachigo83
  Carb question please help MIGGZFSU 3 5,139 03-29-2017 03:06 PM
Last Post: MIGGZFSU
  which connector is this ditn 7 8,361 07-27-2015 11:24 AM
Last Post: pack
  Whining noise HELP PLEASE izanagi 10 13,201 03-26-2015 06:48 PM
Last Post: Komba
  help, puzzled by the radio connector Bean 4 6,398 11-17-2014 11:32 PM
