tacho signal wire
03-23-2010, 09:57 PM
tacho signal wire
Black wire from the ignitor I believe and I wondered if anyone could tell me where it enters the interior through the bulkhead. Just need to tap into it to do a little data logging. Thanks
03-24-2010, 12:06 AM
tacho signal wire
I want to know as well since I want to get an AE86 one time and put my bling bling STRI shift-light on the dash hahaha
-DWG- Drift Wolf Gaming |
03-24-2010, 12:48 AM
tacho signal wire
You can access the tach from the back side of the cluster.......
![]() This is my AE71 cluster... but it is fitted with the AE89(FX16) tach. the wires coming out are in replacement for screws. Go into your wiring manual, figure out which of those leads is the tach signal, and fit a tapping wire under the screw! Dan - You can | OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
03-24-2010, 09:56 AM
tacho signal wire
thanks OST, to be honest I was hoping not to have to remove the cluster !
I just want to catch the wire on its way through. Ideally it would be the ecu side as the other data aquisition will come from the ecu wires. Having just thought about it, is there another engine speed signal I could use from the ecu ? An analogue brain in a digital World |
03-30-2010, 12:27 AM
tacho signal wire
its the black wire on the ignitor comes in through left hand side of bulkhead trace it from the ignitor plug
Run Free and take a Goodline V8FOURCAM32 MK3 Supra Patchwork AE86 from 4AGE to 7AGE to 4AGZE and now 4AGEU20v suzuki cappuccino mondeo TD |
03-30-2010, 12:03 PM
tacho signal wire
passenger side by the ecu then ?
04-06-2010, 10:39 AM
tacho signal wire
IGf square wave comes from igniter.
All old toyota tachos take signal DIRECTLY FROM COIL NEGATIVE! Black with orange stripe near ECU (but nmot connected to ECU) |
04-12-2010, 09:44 PM
tacho signal wire
irishtwincam Wrote:IGf square wave comes from igniter. Okay so thats the wire we need for example: a shift-light or anything like that... -DWG- Drift Wolf Gaming |
| Ae86 tacho | leon205gti | 4 | 8,339 |
01-30-2017 06:25 PM Last Post: leon205gti |
| Toyota COPs tach signal | Jan Pedersen | 5 | 9,057 |
01-14-2014 02:49 PM Last Post: Jan Pedersen |
| Tachometer wire colour | Jezza_hr | 8 | 17,709 |
10-13-2013 03:52 PM Last Post: parrot |
| Tacho wiring for 20V | Bentley | 6 | 20,574 |
07-20-2013 11:09 AM Last Post: fax0815 |
| tacho issues using haltech e6x on 4ag 20v | bluehachi | 5 | 9,501 |
06-05-2013 06:34 PM Last Post: Rasteirinho |
![AEU86 AE86 - tacho signal wire [Image: AEU86 AE86 - tacho signal wire]](http://i79.photobucket.com/albums/j143/oldeskewltoy/ae71/clusterbackwithtachwires.jpg)
