tacho signal wire
03-23-2010, 09:57 PM
tacho signal wire
Black wire from the ignitor I believe and I wondered if anyone could tell me where it enters the interior through the bulkhead. Just need to tap into it to do a little data logging. Thanks
03-24-2010, 12:06 AM
tacho signal wire
I want to know as well since I want to get an AE86 one time and put my bling bling STRI shift-light on the dash hahaha Big Grin
-DWG- Drift Wolf Gaming
03-24-2010, 12:48 AM
tacho signal wire
You can access the tach from the back side of the cluster.......
[Image: AEU86 AE86 - tacho signal wire]
This is my AE71 cluster... but it is fitted with the AE89(FX16) tach. the wires coming out are in replacement for screws.
Go into your wiring manual, figure out which of those leads is the tach signal, and fit a tapping wire under the screw!
Dan -
03-24-2010, 09:56 AM
tacho signal wire
thanks OST, to be honest I was hoping not to have to remove the cluster !
I just want to catch the wire on its way through. Ideally it would be the ecu side as the other data aquisition will come from the ecu wires.
Having just thought about it, is there another engine speed signal I could use from the ecu ?
03-30-2010, 12:27 AM
tacho signal wire
its the black wire on the ignitor comes in through left hand side of bulkhead trace it from the ignitor plug
Run Free and take a Goodline
V8FOURCAM32 MK3 Supra
suzuki cappuccino
mondeo TD
03-30-2010, 12:03 PM
tacho signal wire
passenger side by the ecu then ?
04-06-2010, 10:39 AM
tacho signal wire
IGf square wave comes from igniter.
All old toyota tachos take signal DIRECTLY FROM COIL NEGATIVE!
Black with orange stripe near ECU (but nmot connected to ECU)
04-12-2010, 09:44 PM
tacho signal wire
irishtwincam Wrote:IGf square wave comes from igniter.
Okay so thats the wire we need for example: a shift-light or anything like that...
  Ae86 tacho leon205gti 4 7,651 01-30-2017 06:25 PM
Last Post: leon205gti
  Toyota COPs tach signal Jan Pedersen 5 8,451 01-14-2014 02:49 PM
Last Post: Jan Pedersen
  Tachometer wire colour Jezza_hr 8 16,553 10-13-2013 03:52 PM
Last Post: parrot
  Tacho wiring for 20V Bentley 6 19,568 07-20-2013 11:09 AM
Last Post: fax0815
  tacho issues using haltech e6x on 4ag 20v bluehachi 5 8,797 06-05-2013 06:34 PM
Last Post: Rasteirinho
