starting issue after rebuild
07-25-2007, 05:12 PM
ok my dad just rebuilt my engine
engine has been fitted back into the car and all wired up,
now we are having issues starting it, seems like we are back to where we started before we done the rebuild, not starting haha
when cranking the car it initially turns over quickly, then there is a kind of pop and it doesnt turn over so quickly, sounds like it is coming from around the t-vis, and airfilter area its kind of hollow
there is also a fuel leak from around the injectors but we know that is the seals new set is ordered, could this be causing the starting issues?
my dad thinks the pop noise is a backfire :confused:
anyone got any ideas?
oh and there is an earth lose from the gearboox to the chassis noticed it brfore i came in here, but dont think that would cause a staring issue would it?
[Image: AEU86 AE86 - starting issue after rebuild]
also this lead, does anyone know where it should go?
damn car i just want it back Crying
DRIFTING is pushin a car against its intended design, then playing with the LAWS OF PHYSICS
07-25-2007, 05:50 PM
Blue plug goes to your TVIS under the manifold. Check you have the distributor correctly lined up.
07-25-2007, 07:32 PM
my gues is the distrib take it out and reset it to correct line up. (check 4age manual) then time the engine
07-25-2007, 07:55 PM
Quote: there is an earth lose from the gearboox to the chassis noticed it brfore i came in here, but dont think that would cause a staring issue would it?
Check the wiring diagram and see what is the purpose of that wiring point.
The problem is only with the starter or with ignition/injection?
Keeping the AE86 alive!
07-25-2007, 11:44 PM
also if your backfiring through the intake try setting your intake cam ahead 180 degrees so that those valves are shut during the ingition stroke.
07-26-2007, 03:12 AM
evfan42 Wrote:also if your backfiring through the intake try setting your intake cam ahead 180 degrees so that those valves are shut during the ingition stroke.
?? Before you do this, make sure the dizzy isn't 180 degrees out!
And no, a missing earth won't cause the problem you describe.
  Door mirrors - after market to be specific help me :) ondafly 0 181 08-08-2026 07:36 PM
Last Post: ondafly
  PWR light issue and no brake fluid after winter storage magpie 10 7,499 05-25-2023 08:09 AM
  20 Valve Blacktop smoking after engine flush - why? RolanTHUNDER 2 4,075 11-30-2022 12:09 PM
Last Post: RolanTHUNDER
  Fuel pump issue DJexor 11 10,973 04-29-2022 05:45 AM
  lntermittent starting totta Crolla 6 6,639 08-31-2021 06:21 PM
Last Post: totta Crolla
