some mad lock angle he's got!
04-09-2006, 05:45 AM
I still have not seen anyone outside of D1 with an extreme angle as in the photo. Ken Maeda, Ueo and a few others acheive the amazing. Is the spacer the best we can do?
04-09-2006, 10:49 AM
I think those D1 guys probably use different steering racks with more travel.
I've read something about the TE71 rack having more steering travel than the ae86 for example. FABRICA MI DIEM, PVNC! |
04-09-2006, 04:21 PM
anywhere to buy those steering angle kits?
![]() 1987 AE86 http://www.bilgalleri.dk/html/gal_visbil.asp?ID=41755 http://www.aeu86.org/forum/viewtopic.php?t=3255 ...FWD SUCKS!!... |
04-09-2006, 05:39 PM
Ivan141 Wrote:I think those D1 guys probably use different steering racks with more travel.
05-14-2006, 04:04 PM
Ok guys here is one way to get maximum lock... I mean, the lock in that picture is just stupid and im not sure you couldnt ever really use that much. I know for certain he spun after that cus i have the video but here is a way to get stupid lock..
Firstly, get Battle Version Spacer Kit #2. You'll find that this gives a huuuge amount of lock and unless you have really low offset wheels, the tyre will hit the chassis rail when you get near full lock.. For example my friend Jay has 14x7 0 offset wheels with 25mm spacers and it juuust about clears the chassis but has rubbed all the paint off. But using just the kit alone you'll be very happy.. But here is how to get more: Secondly, if you couple the steering knuckles from a Power Steering AE86 with a Manual steering rack, this also gives a few more degree's lock and if you coupled this with the BV Kit #2 you will have huge problems with your wheels hitting the chassis rail. The reason this works is because the Power steering knuckles are shorter in length that Manual ones. There is a way to get round it and thats a combination of low offset wheels and adjustable lower arms and pillow ball upper mounts. This way you can pull the top and bottom of the suspension further out and it'll give you more clearence for the wheel to turn. Ueo Style are a great adjustable bottom arm but so expensive Btw, either of those methods will work on their own and arent dependant on each other, its just thats how i believe you can get maximum lock possible on an 86. The amount you get is just silly! Driftworks - JSPFab.com - DangerStyle - NightSpirit |
05-15-2006, 09:13 AM
That's one very good post. Maybe we should make how-to or sticky?
Since I used shims on my s13 I installed them on my ae86, then Kas followed, Hrc and now dodo. We are all very happy with this modification, no more problems with parking. Drifting - best fun you can have in your car with your pants on! |
05-15-2006, 06:19 PM
haha...i already love the stock radius of rotation in my hachi, cause it has no CV joints in the front...LoL...
10-01-2006, 05:27 PM
can somebody explain the working principle of this modification... I understand that with a spacer added it can move the wheel more out, but what is the point if you still leave the adjusment of the toe-in out the same... you adjust the tor-in-out, and when you steer you again have the same steering ratio... I didn't quite got the whole idea... I am looking to the manual right now and still can understand...
Can somebody explain this... EDIT Almost got it!!! Hopefully at the end of the day I will be able to explain it to myself, and later on to all of you GEEK LOL(the speed of the steering changes (the trayectori of the wheel changes) because the tie rod has a difrent angle at the begining of it's travel)... SNO-MO-BIRU project started- CHIRO |
10-21-2006, 01:09 AM
Basically - all your doing is giving the steering rack more movement left and right.
When coupled with unchanged suspension geometry it increases angle by allowing you to turn/move the steering knuckle further than before. Which means your wheels turn further = increase tire angle/smaller turning radius. Further gains/losses/clearances can be had by changing other items such as the lower control arms, steering knuckles and wheel offsets. Andrew |
10-21-2006, 01:26 PM
| Thinking of buying a better 86 am i mad ?? | adamsaiyad | 11 | 18,548 |
04-08-2014 11:06 PM Last Post: adamsaiyad |
| just got one! finally! | electric mic | 23 | 31,473 |
11-15-2013 09:34 PM Last Post: YoShImUrA |
| My Wife Got her First Car! | Touge86 | 7 | 10,753 |
12-07-2009 02:05 AM Last Post: Mux213 |
| pic request: extra lock with power steering knuckles | aussiefan | 1 | 4,790 |
07-26-2009 02:02 PM Last Post: aussiefan |
| wish did come true PICS!/ mods lock it please. | jp86 | 11 | 14,807 |
11-24-2007 11:43 AM Last Post: Mux213 |
![AEU86 AE86 - some mad lock angle he's got! [Image: AEU86 AE86 - some mad lock angle he's got!]](http://img.photobucket.com/albums/v356/sultennok/DRIFT20063redigeretnewsignature.jpg)
![AEU86 AE86 - some mad lock angle he's got! [Image: AEU86 AE86 - some mad lock angle he's got!]](http://www.driftparts.nl/Eric/Spaanbanaan.jpg)
LOL
