remove / replace starter
05-25-2011, 09:10 PM
Anyone can explain how to remove the starter?
The manual says: remove wires and the two bolts that's it. That I figured out myselve already ![]() But... I can not get it out in any direction... Do I need to remove any other parts? It is touching the E/G mount or heatshield or... so I can not pull it backward enough. I need to have it replaced before weekend. Thanks in advance. |
05-25-2011, 09:44 PM
I remember, at least that I removed the oilfilter, maybe the oilcooler adaptor, too.
Still wasn´t easy to get it out... Maybe this helps a little :wink: 1979 Toyota Corolla KE35 1983 Toyota Corolla AE86 1985 Toyota Corolla AE86 |
05-25-2011, 11:06 PM
at my gze i removed the exhaust header. and then have clearance to remove the starter.. 2 wires, and 2 bolts, thats it!
Gtsi-R "Trust me, I was an engineer" "straight lines are for fast cars, turns are for fast drivers" |
05-25-2011, 11:14 PM
I undo the wires from the battery, and unclip the 1 wire. Then I remove the heatshield from the starter (a semi pain in the ass). And slide the starter out towards the firewall. Takes some manuevering but can be done.
Andrew |
05-25-2011, 11:38 PM
Gtsi-R Wrote:at my gze i removed the exhaust header. and then have clearance to remove the starter.. 2 wires, and 2 bolts, thats it! That´s by far the easiest option, if you don´t mind spending the bucks on the new gasket
05-26-2011, 08:12 AM
easiest and at least for me fastest option is to remove the header from head. I was able to just slide the OEM off the studs to gain more room to remove the starter towards the firewall. But I don't have EGR or the exhaust to gearbox bracket mounted so that's too things less for me to remove.
if you don't have powersteering or aircon I think the path to the front is also quiet convenient if you plan to make an oil/filter change too. AE86 ex-daily |
05-26-2011, 08:22 AM
OK THanks.
At least I can stop trying to get it out like it is now.... I'll give it a try with the heatshield first. If it doesn't work manifold goes of. Thanks |
05-26-2011, 03:00 PM
assassin10000 Wrote:I undo the wires from the battery, and unclip the 1 wire. Then I remove the heatshield from the starter (a semi pain in the ass). And slide the starter out towards the firewall. Takes some manuevering but can be done. i did his also... didnt take out any other parts... easyer to get the stater out, the hard thing was get it back but like assasin said "Takes some manuevering but can be done." |
05-26-2011, 03:52 PM
All that can be said has been said: but I'll +1 the remove the heatshield solution, as this has worked for me in the past. It's still a hassle, but better than removing the header.
05-27-2011, 02:30 AM
assassin10000 Wrote:I undo the wires from the battery, and unclip the 1 wire. Then I remove the heatshield from the starter (a semi pain in the ass). And slide the starter out towards the firewall. Takes some manuevering but can be done. X2, 15 minutes max to remove, except the heatshield is a PITA to replace, not remove. So what! |
| Passenger roof grab handle - how to remove ? | ondafly | 3 | 1,605 |
02-19-2026 07:20 PM Last Post: ondafly |
| How to replace the steering column UJ? | Mylesmck | 4 | 5,584 |
05-14-2022 07:40 PM Last Post: Ivan141 |
| AE86 starter options | max_ae86 | 12 | 39,261 |
| Starter problems | Widar | 49 | 156,305 |
02-09-2015 10:11 AM Last Post: Ivan141 |
| Starter Motor Help | phill 92 | 3 | 8,096 |
11-25-2013 11:16 AM Last Post: Apsogos |
