rear bilstein B6 shocks 2 types what to choose?
07-22-2021, 01:39 PM
(This post was last modified: 07-22-2021 01:51 PM by Ryo.)
Hello can someone explain me what is difference between bilstein B6 shocks with p/n 24-001540 (rennen) and 24-003193 and what can be working with apex yellow springs? I am planning replacing the old one but no number on them anymore as stickers are unreadable. Application is road use only not tracking or rallying. Just wondering if those marked rennen will last longer perhaps. Our roads are sometimes like rallying after winter especially. Thank you for any help
![]() Link to cataloque: http://web1.carparts-cat.com/default.asp...4=1&12=130 (07-22-2021 01:39 PM)Ryo Wrote: Hello can someone explain me what is difference between bilstein B6 shocks with p/n 24-001540 (rennen) and 24-003193 and what can be working with apex yellow springs? I am planning replacing the old one but no number on them anymore as stickers are unreadable. Application is road use only not tracking or rallying. Just wondering if those marked rennen will last longer perhaps. Our roads are sometimes like rallying after winter especially. Thank you for any help 85' AE86 GT coupe lifetime project since 2005 |
07-22-2021, 03:01 PM
My bet would be that "rennen" stands for short stroke.
Generally speaking, you want to keep as much shock travel as possible for road use, so 24-003193. Also, make sure it mach what you have on the front of the car. |
07-22-2021, 08:03 PM
rennen stands for 'race' as it's German.
So you could assume these are stiffer compared to the others, not shorter per se |
07-23-2021, 08:01 AM
I would go with the regular ones. Lifetime of the shocks isn't related to their stiffness.
I used to have the Apex yellow in combination with Tokico HTS (long stroke) - was a decent ride but nothing compared to the coilovers I bought later. AE86 ex-daily |
07-23-2021, 08:38 AM
Off topic:
Bean what coilovers setup do you have ? (I remember your poll about that, but I don't remember seeing the end result) |
07-25-2021, 04:41 AM
(07-23-2021 08:38 AM)Project D Wrote: Off topic:I bought Shockworks from Australia in the end. The spring rates are more moderate (6/4.5) and the adjustable dampers are matched to the spring rates (in actual usable increments, unlike many of the big brands). Last but not least, they come including the spindle and the height is adjustable without affecting the spring tension or the need to remove the from the car. AE86 ex-daily |
| Anyone farmiliar with hks camshaft types for 4age? | spill86 | 5 | 18,848 |
11-18-2017 11:36 PM Last Post: oldeskewltoy |
| KONI Sports shocks for the AE86... | jondee86 | 11 | 23,995 |
| Question about KONI shocks for an AE92 | Apsogos | 1 | 4,746 |
09-13-2013 07:40 AM Last Post: Apsogos |
| (Video) Tips to choose a good set of tires | Homem Bomba | 1 | 4,938 |
07-22-2013 04:59 PM Last Post: Homem Bomba |
| Rear ae86 rear discs & pad part numbers? | J-86 | 4 | 7,266 |
