rear axel swop
07-29-2008, 05:25 PM
rear axel swop
hey i broken my rear dif 2 times in less then 100km and i relley want to drive a littel moor in it i have a 250hp 4agze with turbo on it and som other mods i yost fittet a supre mk3 gear box and its a okey box but my problem is that i havent got a clue of what hear axel i can run on it have to have e 4,3 final og somthing bicors the supra .box is motch longer in gears and then it have to stand a violent beating
pleas help mii i have to run sd-series on the 12 of orgust and it have to work..ps the old dif and axel was zenki with kazz 2way and i kild both the diff and krown wheel on it yhanks mikkel worholm. denemark |
08-09-2008, 06:55 AM
rear axel swop
Toyota Hilux five stud with LSD. I don't know the tech specs on it,
but if you Google Hilux diff + AE86 + 4AGZE you will find a whole bunch of information. It has been done many times here in NZ Cheers... jondee86 |
08-12-2008, 05:41 AM
rear axel swop
you can also fit an F series, slightly less overkill than the G, I think it's from a cressy. Search is your friend. This one has also been done many times in Oz.
08-12-2008, 05:47 AM
rear axel swop
Many people do the celica rear end in teh AE86 as well.
| Axel anyway to tell the difference? | MIGGZFSU | 7 | 10,123 |
10-24-2017 08:48 PM Last Post: MIGGZFSU |
| A60 Carina rear axel, AE86 parts | nyberrg | 3 | 8,044 |
09-02-2015 09:21 PM Last Post: banpei |
| Rear ae86 rear discs & pad part numbers? | J-86 | 4 | 7,703 |
| GZE Swop with PAS & AC | Lauren | 12 | 17,260 |
02-16-2012 01:04 PM Last Post: heshan |
| Adjustable Rear trailing arm/rear 4 links? | lolali | 1 | 5,546 |
10-03-2009 05:17 PM Last Post: lolali |
