problem again , about leaking half shaft bearing
03-22-2009, 01:03 AM
Thanks Jondee, the oil seal is new and I tried 2. Now I have applied sealant between the oil seal and housing.But Had no time to test .
Next rally is planned for March 29 .... And I also applied a trick a friend gave me about the oil seal spring: Removing the spring , you can open it , as there is a small "screw axis ". Just find it and unsrcew one side of the spring . Just cut , let's say 5mm to 10mm. Screw it again and put it in place . The lip will be more tight and a better sealing can be obtained . Done , but not tested . Just fitted my FC Mazda RX7 calipers , and all must be tested.... REgards Phil Filh Save the RWD cars |
| Play between steering column and intermediate shaft after manual rack sonversion | DaLanZhu | 5 | 8,924 |
| Steering shaft issue | Ryo | 15 | 15,978 |
11-19-2018 09:52 AM Last Post: Ivan141 |
| Half Shafts Poblem | AlexKTM | 6 | 8,400 |
04-23-2018 04:42 PM Last Post: MIGGZFSU |
| 20v mains & big end bearing | izanagi | 9 | 12,449 |
12-26-2016 12:42 PM Last Post: pack |
| Wheel Bearing Temperature | Super86 | 5 | 8,164 |
09-29-2014 12:26 AM Last Post: jondee86 |
