power loss
04-25-2005, 11:44 AM
power loss
Ivan141 Wrote:I would let the ECU run a diagnostic check as well just to make sure it's not something in the electronics. Maybe check out if ignition timing is still correct. i did the timing yesterday in it but no difference. |
04-28-2005, 12:09 PM
power loss
i really need help on this as im trying to sell the car soon. has anyone had a problem like this before.
05-05-2005, 11:02 AM
power loss
the car seems to be reving high when you put your foot on the accelarator but it just doesnt match up with the speed.
05-05-2005, 11:13 AM
power loss
When you put it like that I would suspect the clutch...
05-05-2005, 11:14 AM
power loss
Is your clutch OK? Any smell while accelerating?
![]() http://www.ae86.gr |
05-05-2005, 01:19 PM
power loss
yes theyre is a smell but it isnt a smell of clutch, more of a petrol smell.
05-05-2005, 02:37 PM
power loss
Well, look at it this way: the rpm of the engine is directly proportional to the speed of the car, so if as you say the speed is lower than it should be at a certain rpm, then the only possible cause can be the clutch..
But then again, maybe it's just a feeling your getting.. FABRICA MI DIEM, PVNC! |
05-06-2005, 11:21 AM
power loss
it would honestly say it probably is the cluctch but i dont understand how all of a sudden it is grand and the next day complete difference.
05-06-2005, 11:33 AM
power loss
Possibly a leaking rear crankshaft oil seal..But then you would smell burned oil for sure I think.
| Carbon fibre - weight loss | s.bjelke | 11 | 18,487 |
05-25-2005 11:20 AM Last Post: JonT |
![AEU86 AE86 - power loss [Image: AEU86 AE86 - power loss]](http://i1278.photobucket.com/albums/y508/Euripides86/Pic1_zpsecdf30f3.jpg)
