part numbers on standard cams
09-16-2013, 10:07 PM
where is the part number on a standard camshaft?
09-18-2013, 06:07 AM
16v cams part numbers:
13501-16010 / 13502-16010 (240)
13501-16030 / 13502-16020 (232)
4age 16v to FR 20VT
09-18-2013, 11:05 AM
I know what they are, but were is the part number physically on the camshaft?
09-18-2013, 11:22 AM
Alex170984 Wrote:I know what they are, but were is the part number physically on the camshaft?
For this info a Proffesor of 4age should answer mate
4age 16v to FR 20VT
09-19-2013, 07:36 AM
as fas as i informed the part numbers are not written on the cams.No of the ae92 had the 240 durations cams....for sure someone with experience should confirm this!
4age 16v to FR 20VT
09-19-2013, 07:53 AM
240 cams where on ae86 corolla only.. then you can see easely that cams have less duration.
09-19-2013, 10:29 AM
I had a corolla engine in my aw11 - does anyone have the dimension of a cam on the 240s i can compare mine too?
09-19-2013, 11:12 AM
Aw11 should have the same 240s cams as the ae86, it's the same engine
Daily Beater: Civic EG5
Work in progress Car: AE86
09-19-2013, 01:53 PM
My engine was a bit odd really, as its 7 rib, with 20mm pins but 9.4 pistons
Is that an AE92 or AE86 engine and did the camshafts differ?
09-19-2013, 02:53 PM
I don't think the reference number is engraved on the cams....! Thumbs up!
  Shim size for AM cams kazi 4 7,844 12-18-2017 05:34 PM
  Toda Cams Alex170984 7 12,070 02-11-2017 05:50 PM
Last Post: Alex170984
  20V cams - CATCAMS vs KELFORD? Grant 19 47,233 11-19-2015 07:45 AM
Last Post: hachirokkos
  cams cams cams megabob 60 76,191 12-31-2013 01:19 AM
Last Post: gze spec
  4age 16v 1st and 2nd generation cams and not only difference Apsogos 3 9,389 09-16-2013 08:24 AM
Last Post: Apsogos
