mixing blocks and heads
09-24-2006, 10:47 AM
Mux... I am asking about 4A-FE not 7A-FE.
...you been on medication again?
[Image: AEU86 AE86 - mixing blocks and heads]
Koukis - Red, Silver/Gray,
09-24-2006, 12:09 PM
There is some information
4A-FE and 4A-GE blocks are same.
All crankshaft is not same, all 4A-FE have 48mm/40mm crank and newer 4A-GE have 48mm/42mm crank.
There is at least 2 type of conrods,with 18mm or 20mm upper hole.
Flywheel have 6 or 8 bolts
Anyway, you can use 4A-FE block and put 4A-GE stuff in it.
09-24-2006, 12:34 PM
daytone, oops, sorry, thinking to much about 7's hehehe Big Grin and yes I am on medicene atm Big Grin
09-24-2006, 04:09 PM
S.K. Great!, exactly what I wanted to know.
Mux Big Grin hehehe, I wrote the message at night, and then when I saw your reply, I actually double checked on what I wrote, because I thought I was tripping ;-)
