mintwex 1193 pads ...too small
06-17-2007, 12:48 AM
Hi All,
Have you guys notished that teh front mintex pads are about 5mm to narrow, So that they dont reach the egde of the disk? there must be a great deal of brake power that is lost there? /Skassa Any fool can go fast in a straight line. VEMS Blacktop 4AGTE20V 272hp/350nm """www.turbotoys.dk""" |
06-17-2007, 01:11 AM
Hey Denmark,
I would think that most brake pads leave a little bit of space but you are right that the Mintex pads are smaller, at least compared to the OEM or similar pads I have seen. Still one has to keep in mind that 1193 wasn't made for the Hachi but made for the Diahatsu Charmant which shares alot of components with the Hachi. 1330 (if memory serves me correctly) are the proper pads for the Hachi, but they are only made in 1144 compound to order and that seems to be expensive, at least so my supplier has told me. I am thinking about getting a 1330 normal compound pad next time I order just to see if they fit good and if they are significantly different from the 1193 pads. If business goes well for the mintex pads maybe at some point in time getting 1330's made with 1144 compound may be viable. Greetz, Bastiaan "mux213" Olij Moved down under, no more hachi |
| AE86 Driveshaft too long? [SOLVED] | MyCrazyGarage | 12 | 13,907 |
07-28-2022 10:48 PM Last Post: banpei |
| Can you convert your 86 back too the original state? | gh0st | 7 | 6,427 |
04-25-2022 04:25 PM Last Post: gh0st |
| 4age hitting gas too quick means engine stalls - what is the issue? | Ryo | 20 | 39,533 |
06-27-2018 11:15 PM Last Post: Ryo |
| Early tvis red top from e9 gti small or bigport? | Ryo | 3 | 9,848 |
| Problems Mintex M1155 pads | Dino86 | 9 | 13,165 |
