mild cams... is it worth it?
01-26-2010, 02:17 PM
Hi all.
im soon gonna be swapping my Levin for a nice stock Tureno and im looking into mild tuning.
with regards to cams is it worth using mild cams on a stock ecu or is it a waste of money?
cheers
01-26-2010, 04:18 PM
that realy depends how you drive it and what other mods you have (exhaust in particular) - the oem cams run out of breath a bit below 7k rpm if you want more cams are sure worth it... I'd have a look at the first two catcams.com they have a bit higher lift along with more duration and work quite good on the stock ECU as long as you modify the exhaust a little (if you still have the OEM unit, changing the bit going over the axle helps alot - as it's the most restrictive part)
01-26-2010, 04:26 PM
i will be putting in an aftermarket manifold, exhaust & it already has an aftermarket filter.
what profile would you recommend? it will be used as a daily drive & for occasional track days.
01-26-2010, 04:32 PM
catcam 7105137 was working good on robokills car - this is at the limit of the stock valvesprings and ECU - I think his was running a bit lean at the top - his bottomend was rebuild with bigger pistons though and higher CR if I'm not mistaken. iirc they are 399Euro for the set (cam wheels aren't necessary either - especialy as long as you run the stock ECU).
I myself will go for 7105148 or 9 but this needs quite some changes to the valvetrain... I intend to keep it as dailydriver too but then again I'm not too fused about economy Smile
EDITED price as I made a typo
01-26-2010, 04:43 PM
thanks for the info im not really wanting a great deal of power. just a little more poke. gonna be mostly working on the suspension.
01-26-2010, 07:49 PM
also a quick Q here...
what power gain is possible with those catcam 7105137 ?
thats with stock ecu
aftermarket filter
EU exhaust manifold (no cat) and a hks 60mm catback
'87 levin coupé
[Image: AEU86 AE86 - mild cams... is it worth it?]
01-26-2010, 08:40 PM
I do believe robokill's car was dynoed at about 133hp to the wheels. More than many silvertop 20v's that where dynoed at the same place.
With your setup you will lack the higher compression ratio and the fresh bottom-end plus some headwork of robo's setup.
I'm not experienced enough with these things but I would think anywhere between 110-120 to the wheels should be possible.
01-26-2010, 09:58 PM
that means a power gain of approx 20-25 hp or so?
'87 levin coupé
01-26-2010, 11:02 PM
PatrickAE86 Wrote:that means a power gain of approx 20-25 hp or so?
that sounds about right - unfortunately there are so many aspects to it so it's realy difficult to put concret numbers down.
01-27-2010, 12:00 AM
Bean Bandit Wrote:catcam 7105137 was working good on robokills car - this is at the limit of the stock valvesprings and ECU - I think his was running a bit lean at the top - his bottomend was rebuild with bigger pistons though and higher CR if I'm not mistaken. iirc they are 299Euro for the set (cam wheels aren't necessary either - especialy as long as you run the stock ECU).
Where can you buy these cams for 299 EUR? Is it a pair for this money? Its not so expensive..
  Shim size for AM cams kazi 4 8,041 12-18-2017 05:34 PM
  Toda Cams Alex170984 7 12,289 02-11-2017 05:50 PM
Last Post: Alex170984
  20V cams - CATCAMS vs KELFORD? Grant 19 48,081 11-19-2015 07:45 AM
Last Post: hachirokkos
  Effects of valve lift - worth it going higher? harkes 18 23,730 03-17-2014 09:21 PM
  cams cams cams megabob 60 78,142 12-31-2013 01:19 AM
Last Post: gze spec
