longer wheel studs
02-15-2011, 05:03 PM
longer wheel studs
Hi,
since I´m taking the axles out to fit my new TRD LSD and I probably want to change the wheel studs for longer ones. Has anyone done that before and could tell me the press fit diameter on AE86 axles, I think they´re 14,2mm but I´d like to confirm... Thanks! 1979 Toyota Corolla KE35 1983 Toyota Corolla AE86 1985 Toyota Corolla AE86 |
02-15-2011, 11:16 PM
longer wheel studs
I'm not sure about the exact diameter but I can tell you that you need
to be careful that the splined part isn't so long that it protrudes beyond the hub face. I fitted some that were like this and the wheel nuts would not tighten properly. Apparently Landcruiser studs fit and they are longer but I have yet to find a part number for them. An analogue brain in a digital World |
02-16-2011, 01:31 AM
| longer wheel studs | |||
02-16-2011, 01:32 AM
02-16-2011, 05:32 AM
longer wheel studs
Thanks for pointing me in the right direction!
Little bit more investigation and I should find what I need, thanks.
02-16-2011, 12:25 PM
longer wheel studs
http://s-86.com/s-wstuds.html
MR2 SW20 (MK2) studs for me ! An analogue brain in a digital World |
02-16-2011, 01:13 PM
longer wheel studs
I've read the IS300 studs fit also. You can also use extended IS300 studs for uber long studs.
My Hachi Roku |
02-17-2011, 09:57 AM
longer wheel studs
| Spare wheel & spare wheel carrier | ondafly | 6 | 757 |
01-19-2026 01:00 PM Last Post: ondafly |
| ARP Head studs in a N/A engine, necessary? | Jimmi The Kid | 13 | 18,412 |
02-04-2013 11:27 PM Last Post: Jimmi The Kid |
| Longer 5th gear into T50 | stratosTRD | 3 | 5,957 |
06-16-2011 08:36 PM Last Post: stratosTRD |
| Longer studs | Eric | 4 | 7,329 |
04-29-2011 07:35 AM Last Post: Eric |
| How to fit rear wheel studs without removing the shafts? | Slipangle | 3 | 6,215 |
11-19-2010 10:29 PM Last Post: Slipangle |
