jan speed
10-23-2005, 03:23 PM
Post: #31
jan speed
Hi there,
I just saw a pic of your car in the janspeed topic. That s a gZe, right? I also have a 4agze in my AE, and I wanted to ask how that Janspeed manifold is doing? Sincerely, Achilleas danielvanderwoude Wrote:looks like the nmwisima joke saved you in the end http://www.jdmbits.com
10-23-2005, 03:34 PM
Post: #32
jan speed
No problems,
Good loud sound when the SC is coming. Fitting is also good. I have only make a hole 4 the lamba sensor. I think, its handel the 170 Hp fine. And as you see, i have wrap the maninfold in glasfiber cloth. Do you pics from your car ? Starlet p8 si turbo @ 1.0 bar grey 6,4 sec-> 100 Starlet P9 si turbo @ 1.2 bar black 5,8 sec-> 100 KTM 950 SE ->100 3,2 sec 105 Db ![]() xt660r ->100 4,5 sec BMW 1100 GS->100 4 sec |
10-23-2005, 03:47 PM
Post: #33
jan speed
You can find everything here:
http://www.aeu86.org/viewtopic.php?t=624&highlight= Not as tidy job as yours thou... Since you say 170 and I see 2 alternators, i guess you have late spec ae101 map sensor equiped engine, right? Unfortunatelly, 170 is in JIS japan metric system, so not excactly 170 PS... I use the factory intercooler, front mounted, you should go for the AIR-FILTER, plus i have closed the factory blow-off valve (opens at 0,8 bar), and use an HKS pulley. Now boost raises to 1,11 bar
10-23-2005, 04:33 PM
Post: #34
jan speed
2 alternators?? you meaning the 2 DLI Coils on top off the engine.
Yes I have a AE101 Japan version. I have 0.65 standard boost . i have a HKS pulley on stock , butt have fit the IC yesterday.The air intake must be modify to become fresh air oudsite the car. 4 now its just fine. I use the original fuelpump, and have no problems with the 0.65 boost. Pressure is 3.1 bar under boost. I need first a bigger supra ? pump before i use the HKS pulley. project is 4 the winter when the car is on stock Starlet p8 si turbo @ 1.0 bar grey 6,4 sec-> 100 Starlet P9 si turbo @ 1.2 bar black 5,8 sec-> 100 KTM 950 SE ->100 3,2 sec 105 Db ![]() xt660r ->100 4,5 sec BMW 1100 GS->100 4 sec |
10-23-2005, 04:43 PM
Post: #35
jan speed
I used the stock fuel pump and engine was running lean at 4.500 rpm and more. Now I use an Impreza fuel pump and mixture is reach all way.
I suggest you also close that blow off valve if use the HKS pulley. danielvanderwoude Wrote:looks like the nmwisima joke saved you in the end http://www.jdmbits.com
10-23-2005, 05:07 PM
Post: #36
jan speed
your say that your engine is running lean on the stock pump.
With ore without the HKS pulley ? 3.1 bar fuelpressure seems me right ! That pressure i have til the rev limiters come's. Starlet p8 si turbo @ 1.0 bar grey 6,4 sec-> 100 Starlet P9 si turbo @ 1.2 bar black 5,8 sec-> 100 KTM 950 SE ->100 3,2 sec 105 Db ![]() xt660r ->100 4,5 sec BMW 1100 GS->100 4 sec |
10-23-2005, 05:24 PM
Post: #37
jan speed
Do you have pictures of the sc intake, i'm busy with mounting the 4agze...
10-23-2005, 06:32 PM
Post: #38
jan speed
@toypower: alleen als je de 4agze bij turborolla hebt gekocht
10-23-2005, 06:39 PM
Post: #39
jan speed
Weet niet bij wie die weg kwam, al een 2 jaar geleden ofzo. Misschien dat ik een keer jou kant op reis met camera...
![]() Is het geluid niet te hard geworden ivm supercharger? Op toymods waarschuwen ze aardig voor de 60mm doorsnee dat het geluid te hard wordt. |
10-23-2005, 06:51 PM
Post: #40
jan speed
Nee, hoor geluid is mooi.
net nog ff wat testen gedaan ivm brandstofdruk, ook met IC osteady op 3.1 . Het enigste wat ik hoor is de achteras, en dat is sinds ik de harde rubbers erin heb zitten. Ben ik blij dat ik geen zelf gedraaid nylon bussen erin gezet heb maar voorlopig kan je ook rijden met een bypass op de motor ![]()
![AEU86 AE86 - jan speed [Image: AEU86 AE86 - jan speed]](http://www.castaert.nl/ae86/bypass.jpg)
