is this a smallport or bigport
11-09-2005, 10:26 PM
DJexor: as i recall, fensport.co.uk are selling reconditioned 4a-g engines. A 87-89 redtop goes for 300 UK pounds i think..
11-10-2005, 12:21 PM
yes billzilla says that the combustion chamber on both engines are identical,
the head is lowered and i plan to use metal head gasket, but the benefit is to better the flow in mid range, apolan:87-89are bigports http://www.86ers.org All the hachies that Daytona can only dream about. |
11-10-2005, 12:51 PM
a redtop is a '91 engine isn't it?
but I can ask them (fensport) thanks 5/2018 BMW F22 Coupe 1/1985 Toyota AE86 Levin Coupe |
11-10-2005, 01:29 PM
The 87-89 redtop engine is the 7 rib block with the bigport tvis head.
The engines are low milage used Japanese engines for £395 they also do low milage bluetops at £295 but shipping them anywhere else but the uk would cost lots. I fitted a phase II engine in the past that i got fom them, the thing to remember is that these are fwd engines and need a few bits and pieces swapped over so you can fit them. ..edit.. don't forget to add 17.5% to the prices for tax within the EC |
11-21-2005, 11:55 AM
ok the head was bigport from an 88gti, but complete with polished ports, matched to tvis manifold and exhaust, valves with 3angle job polished, bigger cams 240?, springs etc. i buy it for 100eu as spare,
the guy has also gearbox from ae92 http://www.86ers.org All the hachies that Daytona can only dream about. |
| Smallport coil | totta Crolla | 2 | 3,875 |
08-12-2022 11:03 AM Last Post: totta Crolla |
| Smallport inlet manifold | totta Crolla | 6 | 6,203 |
01-17-2022 05:14 PM Last Post: oldeskewltoy |
| Early tvis red top from e9 gti small or bigport? | Ryo | 3 | 9,881 |
| 10.8:1, 264/256° Bigport | nyberrg | 4 | 8,914 |
06-12-2017 09:57 AM Last Post: nyberrg |
| 4A-GTE 7-rib smallport | nyberrg | 5 | 9,335 |
05-24-2017 09:24 PM Last Post: krullibull |
