is this a smallport or bigport
11-09-2005, 12:59 PM
Can somebody tell me what this is? smallport or bigport?
11-09-2005, 01:10 PM
small
This is big port
Regards Ian. |
11-09-2005, 01:45 PM
jnk Wrote:small Drifting - best fun you can have in your car with your pants on! |
11-09-2005, 02:47 PM
Thanks guys!
Do you think a price of 350 euro is expensive for a brand new smallport head? 5/2018 BMW F22 Coupe 1/1985 Toyota AE86 Levin Coupe |
11-09-2005, 03:04 PM
DJexor Wrote:Thanks guys! Yes. I can't see any benefit of using new head instead of old one. |
11-09-2005, 04:08 PM
And you'll also be needing an intake manifold or buy an adapter that kills a big part of the advantages of the smallport head. I think you could probably find a complete used redtop for not much more if you went looking, which would give you the added benefit of high compression pistons (and thus more torque).
I'd say dont buy it..waste of money. FABRICA MI DIEM, PVNC! |
11-09-2005, 05:13 PM
Okeey thanks for the advise! I won't buy it!
11-09-2005, 06:03 PM
i have chance to buy an rally used small port with optimized and polished ports, lovered etc.
with cams and valves/springs. i plan to put it on 3rib bottom, will the compresion raise or drop (with the standart heads and pistons)? the benefits complete with the AE92 intake are more middle and bottom torgue. i plan reweld the intake and use 60mm 200sx throtle body or custom made airbox later. http://www.86ers.org All the hachies that Daytona can only dream about. |
11-09-2005, 10:09 PM
The compression ratio won't rise, if you're not planning to shave the head or use a thinner headgasket.
Ahhh, VTEC. All the lag, none of the turbo. It's like waiting for bad sex. |
| Smallport coil | totta Crolla | 2 | 3,126 |
08-12-2022 11:03 AM Last Post: totta Crolla |
| Smallport inlet manifold | totta Crolla | 6 | 5,301 |
01-17-2022 05:14 PM Last Post: oldeskewltoy |
| Early tvis red top from e9 gti small or bigport? | Ryo | 3 | 9,129 |
| 10.8:1, 264/256° Bigport | nyberrg | 4 | 8,093 |
06-12-2017 09:57 AM Last Post: nyberrg |
| 4A-GTE 7-rib smallport | nyberrg | 5 | 8,173 |
05-24-2017 09:24 PM Last Post: krullibull |
