is this a smallport or bigport
11-09-2005, 12:59 PM
Can somebody tell me what this is? smallport or bigport?
[Image: AEU86 AE86 - is this a smallport or bigport]
11-09-2005, 01:10 PM
small
This is big port
Regards Ian.
11-09-2005, 01:45 PM
jnk Wrote:small
Thumbs up!
11-09-2005, 02:47 PM
Thanks guys!
Do you think a price of 350 euro is expensive for a brand new smallport head?
11-09-2005, 03:04 PM
DJexor Wrote:Thanks guys!
Yes.
I can't see any benefit of using new head instead of old one.
11-09-2005, 04:08 PM
And you'll also be needing an intake manifold or buy an adapter that kills a big part of the advantages of the smallport head. I think you could probably find a complete used redtop for not much more if you went looking, which would give you the added benefit of high compression pistons (and thus more torque).
I'd say dont buy it..waste of money.
11-09-2005, 05:13 PM
Okeey thanks for the advise! I won't buy it! Thumbs up!
11-09-2005, 06:03 PM
i have chance to buy an rally used small port with optimized and polished ports, lovered etc.
with cams and valves/springs.
i plan to put it on 3rib bottom,
will the compresion raise or drop (with the standart heads and pistons)?
the benefits complete with the AE92 intake are more middle and bottom torgue.
i plan reweld the intake and use 60mm 200sx throtle body or custom made airbox later.
http://www.86ers.org
11-09-2005, 10:09 PM
The compression ratio won't rise, if you're not planning to shave the head or use a thinner headgasket.
  Smallport coil totta Crolla 2 3,787 08-12-2022 11:03 AM
Last Post: totta Crolla
  Smallport inlet manifold totta Crolla 6 6,039 01-17-2022 05:14 PM
  Early tvis red top from e9 gti small or bigport? Ryo 3 9,763 04-20-2018 09:14 AM
  10.8:1, 264/256° Bigport nyberrg 4 8,827 06-12-2017 09:57 AM
Last Post: nyberrg
  4A-GTE 7-rib smallport nyberrg 5 9,180 05-24-2017 09:24 PM
Last Post: krullibull
