intresting (i think) pics of my car (56k WARNING)
05-04-2005, 09:46 AM
Post: #41
The right thing to do would be to go to another technician and make an aluminium strut with oval design so that it would pass over the pipes, which by the way in my supercharged set up are too high...
[Image: AEU86 AE86 - intresting (i think) pics o...k WARNING)] http://www.jdmbits.com
05-04-2005, 11:19 AM
Post: #42
nmwisima, try the tri-bar design ;-)
05-17-2005, 12:48 PM
Post: #43
thats how the car looks like with the 14 inch wheels.
No big diference, of course.
I d kill for an old school design rim Confused
05-17-2005, 01:09 PM
Post: #44
Achillea: I told you before man, Konig Rewind wheels from T3: 325 USD + shipping.
Very new, very oldschool, very good value.
06-29-2005, 11:33 AM
Post: #45
update:
Fuckin' Impreza Recaros are at my home,
but not ready to install.
For me it seems like ALOT OF WORK.
Check out the pics to see what I mean: Angry Angry
06-29-2005, 11:40 AM
Post: #46
more pics
06-29-2005, 12:25 PM
Post: #47
Man, you CANNOT unscrew AE86 seats from their base. Only cut&weld operations are involved.
Your Recaros can be converted to AE86 mounts relatively easy (welding). But this will not eliminate problem with height. Please, compare seat width between recatos and stock AE86 seats !
06-29-2005, 02:38 PM
Post: #48
I think Recaros dimencions are:
width is 430 mm (between bolts)
and 360 mm length (also between bolts).
Does that tels you anything Jammie?
I can give you more precise numbers tommorow
06-29-2005, 02:45 PM
Post: #49
nmwisima Wrote:I think Recaros dimencions are:
Man, make a test-fit with the seat (forget about rails for the moment).
Recently we adapted AE92 GTi seat to the AE86 - if the seat was 10mm wider, it wouldn't fit in the car. As I can see - your seats are not drastic wider than AE86 ones - but just check to be sure.
06-29-2005, 03:07 PM
Post: #50
Most seats end up higher than the ae86 stock seats because you kind of sit between the rails in the stock seats. If these are just for sporty driving pleasure then consider putting them on solid metal mounting plates. Those are easy to make from a flat bar of steel. After cutting up your stock rails there is no going back...I've done this for our senna's car so I know something about it.
You could make adjustment holes as well to find your favourite driving position. Consider it before cutting up your old seats.
  @dodo@ Levin Coupe, renovation and tuning (56k think twice) @dodo@ 165 204,847 03-28-2018 12:35 PM
  Ive been busy.. F20C AE86 (56k badness!) PazzaAE86 46 101,602 06-25-2011 04:49 PM
Last Post: kennedy8383
  Project: My new trackday toy (56k beware!) Morten 88 102,469 02-25-2010 01:44 PM
Last Post: Morten
  Rich's AE86 projectu - 56K crashu rallyman1978 81 96,271 06-02-2009 03:26 PM
Last Post: Melo
  electric's double grey JDM Trueno (56k warning) electric mic 17 23,808 12-21-2007 02:45 PM
Last Post: domi
