intermitant starting problem
03-26-2006, 10:21 PM
right this is annoying me now :mad:
everynow and again the ae86 wont start
i can jump start it and i can bump start it, but i cant start it by key
i had the starter motor solenoids done before i put the car on the road because it wasnt starting at all, and it seemed fine for a few days, since then it just does it every few days.
the electrics come on, and all is fine there, when i turn the key i here the ECU clicking but it doesnt turn over, starting to annoy me,
now these problems didnt start untill i got my alarm and immobiliser fitted, does anyone have any ideas as to what the problem may be????
cheers
[Image: AEU86 AE86 - intermitant starting problem]
DRIFTING is pushin a car against its intended design, then playing with the LAWS OF PHYSICS
03-26-2006, 10:44 PM
immobiliser may nopt be working right...battery might be weak...
also check if the connector to the starter is still tight
03-26-2006, 10:55 PM
battery is quite small, will trace the wiring 2morrow and check that, i sometimes wonder if it is big enough
one other thing is i can sometimes leave it for a few hours and it will start again
03-27-2006, 09:01 AM
I've had the clicking noise before...that was the battery gone bad. I've also had it completely quiet and not even trying to start..that was an immobiliser gone bad and/or the starter signal wire come loose.
03-27-2006, 09:29 PM
Had the same problem: clicking noise and nothing. Battery gone bad, eventhough I charged it enough. Wink
  lntermittent starting totta Crolla 6 7,019 08-31-2021 06:21 PM
Last Post: totta Crolla
  Starting problems 4-AGE kouki Hanzo 3 5,174 08-31-2021 06:20 PM
  JDM trueno not starting. need help! kazi 8 12,995 03-12-2017 05:05 PM
Last Post: kazi
  20v Starting Issues mad.matt 10 17,241 09-24-2014 12:44 PM
Last Post: pack
  starting/electrical issues Jezza_hr 14 25,472 12-21-2013 05:45 PM
Last Post: Apsogos
