intake runner lenght with ITBs discussion
02-20-2010, 02:30 AM
IMHO fitting an airbox (with fresh/outside enginebay air duct) will result in far more better results for cooler intake chare than any insulation between head and manifold...
02-20-2010, 07:31 AM
jondee86 Wrote:
Jimmi The Kid Wrote:I will place my injectors at the end of the stack - oldschool formula 1 trick... Tongue
I have looked at mounting injectors at the mouth of the stack, because
of the more efficient fuel vapourisation. Obviously it works well for any
kind of racing where the throttles are wide open most of the time.
However, my research indicated that there are some drawbacks when
using this system for a car driven on the road. It seems that having the
fuel on the "wrong" side of the throttle butterfly is not so good for idling
and low throttle opening. And probably cold starting will also be difficult.
I'd be most interested to hear from anyone who is using this system on
their road car... and not just as secondary injectors that only come into
action at WOT !!!
Cheers... jondee86
If you look at formula atlantic 4ag's you see they all run secondary injectors infront of the stacks.
Obviously cold start isnt an issue, or is drivability in an open wheeler.
ust check the overall length, and the offset on cylinders 1 and 4 vs 2 and 3
[Image: AEU86 AE86 - intake runner lenght with ITBs discussion]
Brake with the left hand, steer with the right foot...
02-20-2010, 09:32 AM
mc68 Wrote:Just check the overall length, and the offset on cylinders 1 and 4 vs 2 and 3
Been a few bikes using those staggered stacks for a while. It's said to
help broaden the torque band. So, like thermal insulators throttlebody
spacers and Irridium plugs... every little bit helps Smile
Cheers... jondee86
02-20-2010, 10:02 AM
And what do you guys thinkabout those type of adaptor inlet manifolds?
http://cgi.ebay.co.uk/Toyota-4AGE-4AG-16...2eaafe5be2
SR Team
BURN THE RUBER NOT YOUR SOUL!
02-20-2010, 11:58 AM
looking at the quality of the piece in the pics IMHO they are not worth it the T3 one is about 50$ more but have a close look at the inlet side in the auction pics you'd need to do quite some adjustments on those as they are 'hand made'
02-20-2010, 12:21 PM
mc68 Wrote:If you look at formula atlantic 4ag's you see they all run secondary injectors infront of the stacks.
Jup, secondaries are ok, but notice that they also run primary injectors aimed at the valves.
03-16-2010, 01:09 PM
Where do I messure the ideal runner diameter? Is it the throttle valve or what does it means?
Project AE86 now begun.
Cars I have owned:
Toyota Starlet EP91 1,3 16v Turbo, 200hp
Toyota Starlet EP71 1,3 12v Sport
Mercedes 207D camper, 1977.
Toyota Starlet EP70 with a 174hp Silvertop 20v See video here:
http://videos.streetfire.net/search/Star...079edc.htm
Toyota Corolla AE101 with a 164hp Silvertop 20v. (Evolution bodykit and candycolor paint).
Volvo 240 2,1 (The only car I have maked money on).
Toyota Corolla EE90 (my first car)
03-16-2010, 01:31 PM
usualy you take the diameter of the throttleplate unless there is a huge size difference in your runners compared to the throttleplate than you would use an average
03-17-2010, 09:39 PM
Thank you. I messured my AE111 ITB's to 45mm, and this should be close to my target Smile
Cars I have owned:
03-27-2010, 07:45 AM
Im presuming you are using a plenum as well? Trumpets alone without a plenum lose a nice amount of mid range power and torque.
  Newb question on "how-to" guide for ITBs on JDM 4AG Bluetop w/ MAP mister86 12 17,122 02-10-2020 06:39 PM
Last Post: Power_uP
  AE86 4age engine not starts crank ok backfires to air intake Ryo 18 24,048 08-16-2018 01:36 AM
  valve tick on cylender two intake dinkers542 31 37,095 12-15-2014 09:52 AM
  4age blue top from MR2 same intake manifold? dinkers542 8 13,567 11-02-2014 05:24 PM
Last Post: ditn
  4AGE Heat Shielding Intake Gasket asyrigos 11 27,444 04-01-2013 10:58 AM
Last Post: asyrigos
