hks pfc f-con with gcc,help??
03-26-2012, 02:34 AM
just wanted to no how good they are?easy to use,tuning ect....or if they can be used on n/a setup or just sc/turbo.thanks.
03-26-2012, 09:35 AM
I have one here but without the GCC. GCC gives you finer adjustment at various rev ranges I recall.
Make sure you get the loom and MAP sensor, often the map sensor doesn't come with it.
It only manages the fuel, so you can't adjust advance curves. Also be aware they came with a variety of chips to suit particular engine characteristics. I was going to run it with some 268 degree cams and slightly larger than stock injectors. But now going with a TRD ECU I managed to pickup.
  Fitting Air Con (No PS) to LHD AE86 pack 7 7,500 01-07-2024 11:36 AM
Last Post: CCB
  HKS valve springs totta Crolla 3 4,291 05-25-2022 10:24 PM
  HKS Legal exhaust Nakilad 2 6,772 07-31-2019 10:00 AM
Last Post: Nakilad
  HKS 260 8.0 Cam Card d3nso 5 9,327 02-14-2018 08:29 PM
  Anyone farmiliar with hks camshaft types for 4age? spill86 5 20,125 11-18-2017 11:36 PM
