help!!!!
02-17-2011, 08:08 PM
help!!!!
Hi guys,
The other day I went to pick up my car and I went for a test drive and pushed the car a bit to see why its having a miss between 0 - 2500 rpms and suddenly this metal sound came and a kind of a loud noise is coming from the GB now!
It goes off when I press the clutch which means it can be the RELEASE bearing BUT... when I put to 2nd the sound changes to a deeper noise and the vibrations become bigger. Can this be a problem with a GB or can it be just the release bearing??
Please help and advice..
Cheated on my いたずらな女の子 and now I can't get enough of her..
02-19-2011, 12:24 AM
help!!!!
Mayby its the driveshaft? I mean you said it stops if you press the clutch, wich indicates more to something in the clutch region.
Take it of to inspect. Tongue
1979 Toyota Corolla KE35
1983 Toyota Corolla AE86
1985 Toyota Corolla AE86
03-06-2011, 08:39 PM
help!!!!
its the gearbox.. one of the bearings in the counter wheel shattered Sad
a few teeth from 2nd and 3rd also gone Sad Sad Sad
searching for a new T50.. but seems like I need to go to a W58..
any easier GB change than a W58? I hear drive shaft changes need to be done as well Sad
