heat on my head covers
10-16-2007, 11:06 AM
not sure whats up with this
my cyclinder head coversheatsup like hot not sure what it is
i dont have heat covers on my exshaust manifold
could this be what causing my engine to heat up
check raditor to see any problem but no water lost and my fan goes on
and when i drive my heat temp is not near to half or sometimes in the center
also checked oil .motor norm on oil
any ideas i can look at ...
10-16-2007, 01:08 PM
And the problem is? Engines just get hot..them explosions be going on inside them . Smile
Seriously though, if you're not having any problems, than what exactly are you asking Dumb question
10-16-2007, 01:23 PM
but it tend to get very hot like hot hot ..i was told its not suppose to do this ,,,,i no its sound dumb,,,but just wanna be sure
10-16-2007, 01:33 PM
Max_toy Wrote:but it tend to get very hot like hot hot ..i was told its not suppose to do this ,,,,i no its sound dumb,,,but just wanna be sure
The engine isn't overheating on full throttle ??
4AGE is generating a looot of heat for NA... and just a little glitch in your cooling and a lot of problems (head gasket and the stuff)... and it's 20+ years old so glitches do happen a lot Smile
There are some troublesome pipes for cooling system that get messed up, or losing pressure in cooling system that are almost impossible to see but it's enough to get into overheating troubles (like me and mrgud Big Grin )
Toyota scrap yard car park = AE92GTi - AE82GT - KE30 - KP62
10-16-2007, 03:33 PM
When I first got the Ae86 I also thought that it was overheating.
But the temp gauge never went past half of the scale. (mostly on 1/4th of the scale)
On rainy days you can even see the raindrops evaporate on the bonnet/hood.
A friend of mine was driving with me side to side and thought that my engine was overheating aswell...but that's just normal I guess...haha.
11-22-2007, 09:05 AM
Check that your thermostat is not stuck closed. I'm reasonably sure that
the temperature sensor is on the downstream side of the thermostat. So
if the thermostat is stuck closed, very little hot water reaches the sensor.
This means it will still read cool when the engine is hot Huh
It also means that the engine will get hot as there is no water circulating
thru the radiator. Does the top hose get hot ?? Does the engine blow steam
out the radiator overflow ?? Is the water pump belt still there ?? Is your
cooling water the colour of rust ?? Does your chewing gum lose its flavour
on the bedpost overnight ?? :-P
Cheers... jondee86
  4AGE Heat Shielding Intake Gasket asyrigos 11 27,449 04-01-2013 10:58 AM
Last Post: asyrigos
  My new rebuilded denso starter (Heat soaked?) Apsogos 8 10,165 10-01-2012 07:43 PM
Last Post: Apsogos
  AE86 heat unit panel with buttons and sliders Okami 6 12,701 09-09-2012 04:09 PM
Last Post: Okami
  Remove paint from rocker covers xrgeorg 4 7,517 08-19-2011 03:05 AM
Last Post: Lewy
  Heat... I want some heat! amigaguy 8 12,651 09-29-2009 05:44 PM
Last Post: -Mister2-
