gearbox change considerations - ratio's table
09-08-2010, 03:58 PM
I'm considering change of gearbox on my AE86 and after thorough consideration i came up with 20+ different gearboxes with they ratio's.
Many info are still missing but i believe some of you will find this table useful. It's fully editable so everyone can contribute if can. https://spreadsheets.google.com/ccc?key=...y=CNqEs-cI There is a "calculation" part in lower part, it's just needed to input circumference of tyres, max RPM of engine and final ratio if different than stock 4.3:1 Regards |
09-11-2010, 03:06 PM
Ford Type 9 Quaife internals:
1st gear 2.39 2nd gear 1.54 3rd gear 1.21 4th gear 1.1 5th gear 0.87 Definately needs 4.8 final drive minimum, probably better with 5.1 An analogue brain in a digital World |
09-11-2010, 06:01 PM
Dogboxes:
Lampola T50: > 2,25 > 1,72 > 1,38 > 1,15 > 1 Quaife T50: * First Gear: 2.347:1 or 2.600:1 * Second Gear: 1.733:1 * Third Gear: 1.379:1 * Fourth Gear: 1.144:1 * Fifth Gear: 1.00:1 http://www.sg-rallyesport.de |
| trans oil, lsd oil change | Apolan | 9 | 21,161 |
| Ring & pinion ratio. | izanagi | 27 | 35,578 |
07-05-2014 07:35 PM Last Post: assassin10000 |
| Change the meter between zenki and kouki | T_AE86 | 9 | 14,166 |
12-03-2012 03:13 PM Last Post: T_AE86 |
| 5.375 final drive ratio with stock T50 | 4000GT | 23 | 33,328 |
08-07-2012 01:08 PM Last Post: 4000GT |
| More positive gear change | phill 92 | 12 | 16,121 |
05-21-2012 10:51 PM Last Post: phill 92 |
