gearbox change considerations - ratio's table
09-08-2010, 03:58 PM
I'm considering change of gearbox on my AE86 and after thorough consideration i came up with 20+ different gearboxes with they ratio's.
Many info are still missing but i believe some of you will find this table useful. It's fully editable so everyone can contribute if can.
https://spreadsheets.google.com/ccc?key=...y=CNqEs-cI
There is a "calculation" part in lower part, it's just needed to input circumference of tyres, max RPM of engine and final ratio if different than stock 4.3:1
Regards
09-11-2010, 03:06 PM
Ford Type 9 Quaife internals:
1st gear 2.39
2nd gear 1.54
3rd gear 1.21
4th gear 1.1
5th gear 0.87
Definately needs 4.8 final drive minimum, probably better with 5.1
09-11-2010, 06:01 PM
Dogboxes:
Lampola T50:
> 2,25
> 1,72
> 1,38
> 1,15
> 1
Quaife T50:
* First Gear: 2.347:1 or 2.600:1
* Second Gear: 1.733:1
* Third Gear: 1.379:1
* Fourth Gear: 1.144:1
* Fifth Gear: 1.00:1
http://www.sg-rallyesport.de
  trans oil, lsd oil change Apolan 9 21,971 10-01-2014 03:57 PM
  Ring & pinion ratio. izanagi 27 37,201 07-05-2014 07:35 PM
Last Post: assassin10000
  Change the meter between zenki and kouki T_AE86 9 15,021 12-03-2012 03:13 PM
Last Post: T_AE86
  5.375 final drive ratio with stock T50 4000GT 23 34,458 08-07-2012 01:08 PM
Last Post: 4000GT
  More positive gear change phill 92 12 16,848 05-21-2012 10:51 PM
Last Post: phill 92
