fuel ron rating in europe
04-06-2008, 05:14 PM
ive been reading up on the high comp engine tuning route through this forum
what fuel do you guys use in high comp 4age engines?
i run shell v power 98octane in my skyline as its the highest quality pump gas we have here
as my car is a japanese import im assuming even this 98 octane isnt great compared to jap fuel,i hear they have 110 pump gas?
are the standard fuel trims on the standard ecu able to cope with lower octane fuels?
should i be worried about it at all with my non turbo hachi?
any input welcome as im looking to use effective well thought out mods to improve my engine rather than spend a fortune or go 20v
[Image: AEU86 AE86 - fuel ron rating in europe]
04-06-2008, 09:11 PM
The early 4age engines were designed to run at least on 91 octane, so I assume later spec engines were designed to run on higher grade like 95 for instance. So imo 98 should be perfect for your high compression 4age.
I mostly used 95 in my hachi (low compression) and didn't find much difference between running on 95 or 98 except in the wallet. Wink
  E85 in europe (Central - Eastern) ?!? Uzelac 4 7,482 04-04-2017 05:38 PM
Last Post: MIGGZFSU
  what is correct name of AE86 in Europe Uzelac 13 20,818 02-01-2009 07:57 PM
Last Post: sawa
  Where: Eibach pro springs in Europe? El_Camino 7 10,546 07-22-2008 07:54 PM
  Toyota MR2 MK1 4AGE fuel rail same as hachi fuel rail ? Ian.G 3 6,369 09-16-2005 09:22 AM
Last Post: jamiemirror
  Kamikazee cams. Any good? Or other cam sources in Europe? XJS 3 6,562 08-20-2005 10:13 AM
Last Post: SekiguchiUeno
