fuel regulator do i need one
10-10-2007, 01:36 PM
i recenlty did a twinconverson but running a weber carb on it ..i connected a filter from the tank and from there the fuel pump and ran the pipe direct to the carb do i need a fuel aswell regulator
10-10-2007, 02:43 PM
Depends on the type of fuel pump and the fuel pressure that is being produced. Supposedly Webers have a fuel-pressure sweetspot that they like running on (very low if I remember correctly) but a google search will show up results without problems.
If the fuel pressure is low enough, then you can just hook the carb up. If its to high, you either need to switch pumps (easy) or run a FPR and a fuel return line (irritating work). Just hook up a fuel pressure meter to the rail and measure..always handy to have around when diagnosing problems with the car anyway.
  Build your own adjustable fuel pressure regulator ;) oldeskewltoy 8 25,738 08-19-2018 12:08 PM
Last Post: AlexKTM
  4AGE Fuel Regulator Alex170984 6 12,828 02-24-2016 05:59 PM
Last Post: totta Crolla
  adjustable fuel pressure regulator on stock 4AGE fax0815 8 22,533 01-07-2012 02:37 AM
Last Post: oldeskewltoy
  Fuel pressure regulator? heshan 18 21,958 05-10-2010 04:17 PM
Last Post: heshan
  Fuel Pressure Regulator needed for a AE86 heshan 2 5,136 02-26-2009 10:35 PM
