false speedometer readings
02-06-2008, 11:08 PM
Thanks a lot man !!! Respect! Respect! Respect!
02-06-2008, 11:11 PM
no thanks, buy me an Ouzo whenever i'm in your area Tongue
02-07-2008, 09:29 AM
A whole barel for you my friend !!! Thumbs up!
02-07-2008, 02:37 PM
alimonos:
Try that and then let me know how accurate became the speedo...
I didn't know about that two version of the speedo gear... Angry
Keeping the AE86 alive!
02-07-2008, 03:32 PM
btw, before you order parts, please check which wheel you have, because i'm not sure if i'm right about which one you need Smile
my maths suck since i left school 4 years ago Tongue
Because, when i think about it right now, you probably need a 19, while there SHOULD be a 22 in right now, but as i said, check that before ordering Smile
02-07-2008, 04:02 PM
I have a 19, 20 and 22 tooth here (none for sale by the way). Bear in mind there is another gear this meshes with inside the gearbox in either a 5 or 6 tooth. See here, will help you work out the gears you require.
http://www.ae86drivingclub.com.au/board/...ntry418230
02-07-2008, 09:37 PM
Yes, for sure the gear inside the gearbox can't be the same...
02-07-2008, 09:54 PM
from what i saw in the australian topic i probably have the 5 teeth inner gear with 19teeth outer plastic gear . So i need the 21 teeth but as i can see above in Doctor's reply there is only the 22teeth version available ...
I 'll check it out as soon as i find some free time these days ...
:wink:
02-19-2008, 12:18 AM
well guys i checked my T50 and i have a 22 teeth speedo gear.
So if i want to fix the problem (speedo shows 20% more than actual kms)i need a 19teeth one ? Dumb question
Anybody have one ???
02-19-2008, 04:56 AM
Might be easier getting one from Toyota. A late TE72 (T18 in Australia had a 19 tooth). They were only about $AUS50 new. i believe that is complete with the drive shaft.
If you get really stuck, I could probably source one through Toyota here and post it.
  Digital speedometer on stock dashboard FanIsHere 0 3,199 11-09-2022 01:36 PM
Last Post: FanIsHere
  NEED a cable for speedometer makkuro 3 6,944 01-01-2012 07:33 PM
Last Post: makkuro
  Gearbox Speedometer Driven & Drive Gear apardal 6 9,720 12-20-2010 10:16 PM
Last Post: ae86rebuild
  Does anyone know of a system to have the following readings? heshan 18 21,396 07-31-2010 10:34 PM
Last Post: heshan
  Digital Tacho/Speedometer akmal86 4 8,066 10-14-2008 06:02 AM
Last Post: F0Bman
