false speedometer readings
02-06-2008, 04:26 PM
How can we make our speedo showing the right speed after we 've installed a 4.778 cp ????
Anybody knows something ???
AE86 FANATIC!!! |
02-06-2008, 04:52 PM
change gear drive in gearbox, but i don't know if you can get one for an aftermarket R&P
02-06-2008, 05:41 PM
or the gear drive on your gauge cluster
![]() Cump“s Filipe Oliveira |
02-06-2008, 09:07 PM
can you be more specific guys ??? where can i find them or part numbers ?
Doctor the 4.778 is a TOYOTA one not an aftermarket one . AE86 FANATIC!!! |
02-06-2008, 09:46 PM
alimonos, i'm studying it...
I've searched in EPC for old RWD Toyotas with a final gear ratio close to 4.778 and i found one that it's close (i can't remember the model). My idea is to order the pinion and gear from the gearbox of that model and try to install in my T50. My two main doubts is to know if it will fit T50 and if those parts are still available from Toyota Dealers. I hope i could help you... Keeping the AE86 alive! |
02-06-2008, 09:47 PM
ok.
In your gearbox is a plastic wheel, which rotates on the outputshaft. It comes together with the R&P, but if you buy a new R&P the wheel isn't there. ![]() ![]() as you see, there are 2 types, one with 22 teeth and one with 19 teeth. i *think* that you have the 19 teeth version now, and probably need the 22 teeth version, but you have to check out which one you've got, it's on the plastic wheel, somewhere
02-06-2008, 09:51 PM
Thanks a lot Doc !!!
AE86 FANATIC!!! |
02-06-2008, 09:53 PM
oh, and please BE SURE TO REPLACE EVERY SEAL YOU SEE IN THE SPEEDO GEAR DRIVE SET!!!!! (yes, it's ment to be in caps
).I once destroyed a box due to a leaking speedodriveseal, didn't knew it was leaking and drove 300 kms without oil in the box. Needless to say it didn't like that "It's all about the heart, the people who focus on parts, turbo's and all that stuff...they're just losers." -Shinji Minowa |
02-06-2008, 10:11 PM
do the seals come with the gear or i can find them elsewhere ?
AE86 FANATIC!!! |
02-06-2008, 10:39 PM
the part number you see, should be the kit with some new seals
![]() And if it's not, this is the number for the seal: 90310-09001 "It's all about the heart, the people who focus on parts, turbo's and all that stuff...they're just losers." -Shinji Minowa |
| Speedometer broke and check engine light | sheppardpat47 | 19 | 3,518 |
10-02-2026 02:04 PM Last Post: jomme_mega |
| Digital speedometer on stock dashboard | FanIsHere | 0 | 3,492 |
| NEED a cable for speedometer | makkuro | 3 | 8,397 |
01-01-2012 07:33 PM Last Post: makkuro |
| Gearbox Speedometer Driven & Drive Gear | apardal | 6 | 10,509 |
12-20-2010 10:16 PM Last Post: ae86rebuild |
| Does anyone know of a system to have the following readings? | heshan | 18 | 22,667 |
07-31-2010 10:34 PM Last Post: heshan |
![AEU86 AE86 - false speedometer readings [Image: AEU86 AE86 - false speedometer readings]](http://lipinhu.no.sapo.pt/sbanner.jpg)
![AEU86 AE86 - false speedometer readings [Image: AEU86 AE86 - false speedometer readings]](http://www.uwhost4.net/~hachi/speedo1.jpg)
![AEU86 AE86 - false speedometer readings [Image: AEU86 AE86 - false speedometer readings]](http://www.uwhost4.net/~hachi/speedo2.jpg)
