enine trouble
04-07-2005, 08:26 PM
enine trouble
recently i discovered a different noise coming from my car like it was missing. i looked at the engine and realised that their was oil leaking from under the distributor cap. i think the seal might be gone on it. does anyone know how to replace this, and is it easy to get a new one. its a 86 4age engine by the way.
04-07-2005, 08:37 PM
enine trouble
Loosen the 2 bolts holding the distributor. Pull out the distributor from the head and change the oil ring on the flange. Put the distributor back in and adjust the ignition. (OR mark the exact point where the distrubutor stands BEFORE disassembly)
04-07-2005, 08:43 PM
enine trouble
mark distributor in relation to the head using white paint or puchmarks (this is so the ignition timing is not out when you replace the distributor)
however: Quote:recently i discovered a different noise coming from my car like it was missing i dont think this would be a result of your distributor oil seal check all your ignition leads and spark plugs, check your distributor cap and rotor arm and adjust your ignition timing Run Free and take a Goodline V8FOURCAM32 MK3 Supra Patchwork AE86 from 4AGE to 7AGE to 4AGZE and now 4AGEU20v suzuki cappuccino mondeo TD |
04-07-2005, 08:58 PM
enine trouble
would a local motor factors have one of these rings or are they hard to get.
04-07-2005, 09:42 PM
enine trouble
I would say, that they are pretty easy to get hold on. There are absolutely nothing special about it.
04-07-2005, 10:11 PM
enine trouble
nice one for the help lasd. thanks.
enine trouble
nice one for the help lads. thanks.
04-08-2005, 03:24 PM
enine trouble
205t16
most of the factors wont have a clue with us.ur better of heading to the local toyota.should be onlt a few yoyo.i replaced mine a while back. Id say u real problem would be dampness on the plugs.take them all out a check for water its only a 30min job |
| gearbox trouble | fax0815 | 2 | 5,556 |
02-17-2011 03:18 AM Last Post: fax0815 |
| Differential issue - extreme huge trouble | MartinS | 9 | 25,229 |
04-27-2010 10:17 AM Last Post: irishtwincam |
| 4AGE. Is it worth the trouble? | Gnugfur | 21 | 30,694 |
01-14-2009 03:13 PM Last Post: Menti |
| 4agze trouble! | SNIFF MY DIFF! | 3 | 5,406 |
11-22-2007 10:59 PM Last Post: Ivan141 |
| AE86 Axle trouble. | rhmeed | 8 | 9,714 |
02-10-2007 03:40 AM Last Post: oldeskewltoy |
