driveshaft center bearing issue
06-02-2012, 11:10 PM
i have total transplant 4AGE & part to my KE70, after two years+ my drive shaft center bearing start shake. wondering the KE70 center bearing set can fit into AE86 longshaft? wil there same inner shaft diameter?
06-03-2012, 03:46 AM
What do you mean by center bearing? differential bearing? diff input bearing?
AE86 and KE70 have different axle codes T for AE86 and iirc U for the KE70, therefore diff, axles, etc won´t fit into each other.
1979 Toyota Corolla KE35
1983 Toyota Corolla AE86
1985 Toyota Corolla AE86
06-03-2012, 12:00 PM
sorry for the unclear description, plz do refer drawing where part in circle. did u have any ideal on it? tq
06-03-2012, 01:54 PM
Sorry, now it makes sense Wink
Have you compared the partnumbers on http://www.toyodiy.com/parts/??
06-03-2012, 03:08 PM
AE86: 37230‑12050
KE70: 37230‑12040
eBay.com:
http://motors.shop.ebay.com/eBay-Motors-...313&_rdc=1
"Tämmösellä modernilla autolla, niin mun mielestä, ei tämmöstä kisaa voi ajaa. Tää käy kunnon päälle eikä riitä aivot tähän touhuun!"
""With a modern car like this, in my opinion, a competition like this can't be driven. It's too physical and your brains can't cope with this stuff"
-Henri Toivonen 2.5.1986-
http://www.youtube.com/watch?v=OwgB4Xs4LVQ
06-12-2012, 08:05 PM
I had a same issue and I bought a malaysian similar center bearing and my mechanic took the outer shell of my old bearing setup and put it onto the new one.
Wana try and out? My issue was the center bearing had a bad play in it and the rubber dampers around it had lost its shape..
Cheated on my いたずらな女の子 and now I can't get enough of her..
06-13-2012, 01:24 AM
https://www.powertrainindustries.com/cat...ies=Toyota
part number 2380-40
Dan -
11-30-2012, 12:06 PM
Dear "Heshan", did u have more detail on the "modification"? if good with photo. (photo tells every thing)
tq
heshan Wrote:I had a same issue and I bought a malaysian similar center bearing and my mechanic took the outer shell of my old bearing setup and put it onto the new one.
  PWR light issue and no brake fluid after winter storage magpie 10 6,165 05-25-2023 08:09 AM
  AE86 Driveshaft too long? [SOLVED] MyCrazyGarage 12 12,037 07-28-2022 10:48 PM
  Fuel pump issue DJexor 11 9,042 04-29-2022 05:45 AM
  Restoring original pizzacutter center caps banpei 17 13,523 06-24-2021 10:58 PM
  Kaaz 1.5 way Diff - Driveshaft Compatability chrisae86 1 3,473 05-10-2021 01:02 PM
Last Post: Project D
