distributor prob
12-15-2010, 08:20 PM
distributor prob
Hi guys my ae86 distributor started leaking and since i had a spare distributor off an AW11 i decided to put it on.
I installed the AW11 distributor and now the car runs crappy, Before install i set TDC on the engine and made sure the rotor arm is at the 1 position (on the cap) Once installed it struggled to start so I twist the distributor all the way clockwise and it will run but really not well, if i twist it anti clockwise the engine will struggle and slowly cut off. Im using aw11 cap and leads aswell Car was running fine with the original distributor I dont know what i missed any help appreciated thx, Alex |
12-15-2010, 08:26 PM
distributor prob
Until someone with better knowledge answer..
Are both cars MAP/AFM ? Maybe you mixed it up ? Checked if all leads/sparks are firing ? |
12-15-2010, 08:50 PM
distributor prob
I dont know if i mixed up as i searched around and ppl has used aw11 distributor on ae86's with no probs
will check the leads tmr as its dark now, i used the aw11 ones, but will try the 86 leads tmr |
12-15-2010, 10:56 PM
distributor prob
If I´m right the AFM dizzy has a different plug for rpm signal but not sure...
Swap over the finger/ cap and leads from the AE dizzy if its still there, check the diagnosis codes, mayby your engine can tell you whats wrong
12-15-2010, 11:04 PM
distributor prob
the plug from the aw11 dizzy (yellow plug) plugged straight into the loom no probs
and looks the same as the 86 one I will check/use the leads and rotor arm from the 86 dizzy as i cant use the ae86 cap as the holes wont line up |
12-15-2010, 11:52 PM
distributor prob
It sounds like the distributor is a tooth out.......
12-16-2010, 12:33 AM
distributor prob
damn lol
will re-install the dizzy again once i check lead and arm |
| 16v distributor hole plug | harkes | 8 | 13,435 |
10-12-2016 11:13 AM Last Post: harkes |
| Changing distributor when carb 4age | izanagi | 14 | 22,613 |
07-04-2016 03:27 PM Last Post: Uzelac |
| Distributor position and cranking | pack | 13 | 26,405 |
07-01-2013 11:08 PM Last Post: pack |
| weak spark. new distributor? please help. | stasis_dc5 | 3 | 9,356 |
04-11-2011 12:35 AM Last Post: fax0815 |
| 4age distributor, what's similiar ? | Uzelac | 3 | 7,141 |
11-11-2010 01:25 PM Last Post: Uzelac |
