differential lock %
04-11-2013, 02:26 PM
differential lock %
This time Im trying to collect differential data.
But I want to focus on lock percentage.
I know the stock car was available with open and LSD diff's
But I am unable to fint what was:
- side bearing preload
- power-side lock %
- coast-side lock %
Could You please help, and share some information ?
04-11-2013, 06:01 PM
differential lock %
There is quite a bit of information available in the factory service manual.
Besides the FSM, you can also trackdown the TRD Bible. This has quite a bit of useful information, and it is available digitally......
Finally, there is a newer TRD publication I've not yet seen digitally... here is a photo of its cover
[Image: AEU86 AE86 - differential lock %]
Dan -
04-11-2013, 11:18 PM
differential lock %
I currently have two books and two FIA homologations.
There are some info but unfortunately not things about which I ask.
I have FSM and TRD Bible, Im biding two other books in GB now.
And I just won auction in PL.
We will see...
...anyway the book that You espouse looks very promising - but I dont think that it is available in Poland :-/
04-12-2013, 08:10 PM
differential lock %
oldeskewltoy
That book is a summary of all suspension pieces for Toyotas or a vehicle specific book?
04-12-2013, 11:41 PM
differential lock %
Sgonzalez Wrote:oldeskewltoy
I don't know.... I take it at its word... it is a suspension data book... I believe it is all their offerings
Dan -
04-17-2013, 06:37 PM
differential lock %
I found some open diff data from other RWD Toyota model with the same engine - side bearing preload is 0.8-1.4Nm for new bearing
and 0.4-0.7Nm for reused ones
As far as I know, open diff was available on U.S. market, does someone have an US service manual to verify this data ?
04-17-2013, 08:17 PM
differential lock %
damusto Wrote:I found some open diff data from other RWD Toyota model with the same engine - side bearing preload is 0.8-1.4Nm for new bearing
You definitely want to get a factory service manual. I have the US manual and there isn't a side bearing preload old/new bearing listing*.... there IS a new/used pinion bearing preload......
1.0-1.6N-m for new bearing, .5 -.8N-m for used bearing
Side bearing pre-load is tighten and measuring backlash
I'm not sure where you can get a factory service manual for your European based model... but the US FSM is available here - http://www.faxonautoliterature.com/
Dan -
04-17-2013, 10:01 PM
differential lock %
OK thanks a lot, when it comes to upper limit I found a description of rally Gr.A car where I found:
"2 way LSD (shimmed to 80%)"
It does not change the fact that I'd to know how does look typical LSD options.
  Differential specs MatuOjav 2 1,801 12-03-2025 07:06 PM
Last Post: MatuOjav
  Door lock disassemble RWD 3 4,560 03-17-2022 02:03 AM
  Rear Differential rebuild chenfon 10 16,125 11-20-2020 12:18 AM
Last Post: totta Crolla
  Lower arm hits toe arm on lock... fullybuiltmiata 12 19,728 01-14-2016 11:52 PM
Last Post: Deuce Cam
Exclamation Some information for those who are about to restore their differential krullibull 0 4,836 06-06-2015 12:44 AM
Last Post: krullibull
