dash temp guage not working 87 coupe UK spec
04-21-2007, 12:38 PM
Hi folks, the temp guage in the car ain't working.
How does it work and where is the temp picked up from for it to work thanks Paul Live life on the red line |
04-21-2007, 12:47 PM
The temp sensor is just upon the waterpump.
So check first the connection. 1982 Toyota Corolla KE70 1992 Subaru Legacy BF5T |
04-21-2007, 12:52 PM
Not sure where it is exactly on a 4A-GE but there should be a plug tapped into the engine somewhere with one wire attached to it. This plug serves as the pickup for the temperature gauge.
Start by cleaning up the connectors. If it is still not working see if the gauge moves to a different position if you either disconnect the wire or connect it straight to the engine block or some other good mass point. If so, replace or clean the sensor (the plug). |
04-21-2007, 12:53 PM
Ah, some guy types faster then I do and was more into 4A-GE aswell... Well, there you have it it's above the waterpump :-)
04-22-2007, 06:02 PM
thanks
when I've cleaned up the single wire connector to the temp sensor on the waterpump and I turn on the ignition....the guage on the dash filckers for a second but still doesn't move from the bottom of the scale (after the car has been run and warmed up) the tacho also does the same "flicker" I've tried direct wiring the wire to the waterpump body but still no joy any further ideas? Is there a way of testing the dash guage with somethimg like a multimeter? thanks Paul Live life on the red line |
04-23-2007, 12:36 AM
just a thought....is the fan supposed to run all the time or is it a viscous coupling controlled by a relay.
The fan on mine seems to be on all the time....this wouldn't allow the car to warm up....maybe its the fans relay thats faulty...any ideas where it is if this is the case thanks Live life on the red line |
04-23-2007, 12:14 PM
Stig Wrote:just a thought....is the fan supposed to run all the time or is it a viscous coupling controlled by a relay. Viscous clutch is self-controlled, there is no external components so don't worry. If your works all the time, you need new viscous coupling (better use electric fan+thermo-switch). |
04-23-2007, 05:17 PM
It is normal for the fan to turn all the time, it just works harder when it gets hot (less slip from the viscous coupling). If your car really doesnt get warm, it's more likely a thermostat failure. Should still get warm if you let it run stationary for a while though, but it will stay cold when there is any significant driving wind through the radiator.
04-24-2007, 10:00 PM
thanks for that....looks like I still need a way of testing the dash temp guage then
| Looking for jdm spec body repair manual | AE111 | 0 | 1,083 |
10-08-2025 10:33 AM Last Post: AE111 |
| STL file for the early spec Levin headlight ball joint plastic clip | DaLanZhu | 2 | 2,532 |
04-26-2025 03:24 PM Last Post: DaLanZhu |
| Digital Dash | evfan42 | 190 | 328,560 |
05-03-2024 06:44 PM Last Post: banpei |
| Brake lights not working | takumi_mt | 2 | 2,445 |
03-07-2024 03:42 PM Last Post: takumi_mt |
| Converting Jap Spec wing mirrors to UK spec | chrisae86 | 5 | 5,144 |
04-12-2022 11:03 PM Last Post: chrisae86 |
