d3nso's little AE86 N2 build
06-26-2013, 11:54 AM
About the bc-racing coilover-kit, is the height adjustment at it's lowest at the pic's or is there any clearence going lower ? :wink:
Could be one of the coilover options, just interested how it "fits" Drive fast, or crash when trying... |
06-26-2013, 12:13 PM
The Front can put on the ground if wanted, at the rear i can go about 1.5cm lower before it reachs the max lowring the kit offers
The first pic was near stock height btw :wink: Daily Beater: Civic EG5 Work in progress Car: AE86 |
06-26-2013, 05:31 PM
What are the f/r spring rates on your set ?
And what do you feel about the handling ? Is it hard as hell, or comfort enough for everyday cruizing.. And btw, what size are your wheel/tyre combo ?
06-26-2013, 10:35 PM
Springs should be f-8kg/r-6kg.
Hm I drive a 08 Suzuki Swift Sport as daily und the BC is alot harder then the sport setup of the Swift, even on the softest damper setting. But if you like it bit harder dann usual it's good. I would drive it on a daily :wink: Tires are 195-50-15 Yokohama A539, great Tires. Wheels are 15x8, offset unknown, will check it next time at the Garage if needed.
06-27-2013, 07:39 AM
No need to check the offset, was just interested on the wheelsize, and the stance.
Thanks alot for all the info, like to hear an opinion on driveability and etc. from someone that actually uses the coilover set rather than someone that sells them, or has looked the specs on internet.
07-01-2013, 09:45 PM
herzlich willkommen,
sieht sehr schön aus;-) bist du im Toyota Forum angemeldet? ist das bc racing eingetragen?habe auch eins in meinem corolla und bereite ihn für den tüv vor ;-) schau mal hier rein;-) http://board.toyota-forum.de/showthread....?p=1829434 lg max |
07-01-2013, 10:18 PM
Danke, jap bin dort ebenfalls angemeldet, war aber bisher nur passiver mitleser
Eingetragen ist leider ganichts, muss sowieso erst noch deutsche papiere beantragen, bzw Vollabnahme machen lassen. Da werd ichs mal versuchen ob ich das Fahrwerk durchbekomm, sonst hab ich n Problem, da ich kein Orginalfahrwerk habe :roll: Gruß, Timo Daily Beater: Civic EG5 Work in progress Car: AE86 |
08-16-2013, 11:22 AM
So time to update the project.
Since I moved to a new garage nothing reallly changed, because I got no space to work at the car. But I managed to get this piece of engineering ![]() Condition is good, seems like it has run >100.000 KM. The bad thing is; no crank and flywheel. Daily Beater: Civic EG5 Work in progress Car: AE86 |
04-08-2017, 07:25 PM
(This post was last modified: 04-08-2017 07:53 PM by d3nso.)
Long time no update. Went to University the past Years so no time and money to continue the project. But now I'm restarting the project
![]() Spent the last few weeks with taking out interior and started with removing the old undercoating: ![]() ![]() ![]() ![]() ![]() ![]() This work is a pain to do...
04-14-2017, 08:56 PM
Great to see you back on the porject!
And so much you cleaned up already! 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop:
| (Catching up...) OST-085: 7AG Big Valve build w/Cat Cams 262 9.0mm lift cams | oldeskewltoy | 5 | 5,007 |
| OST-050 - a VERY special build | oldeskewltoy | 49 | 46,564 |
01-05-2019 07:03 PM Last Post: oldeskewltoy |
| Beams Levin build | mannix20vt | 5 | 11,256 |
01-27-2016 12:39 AM Last Post: mannix20vt |
| Drift missile build [FIN] | TuGeTu | 7 | 22,901 |
11-09-2015 06:13 PM Last Post: mad.matt |
| My panda ae86 build | Ellzbmx | 10 | 20,530 |
06-03-2015 10:56 AM Last Post: Ellzbmx |
![AEU86 AE86 - d3nso's little AE86 N2 build [Image: AEU86 AE86 - d3nso's little AE86 N2 build]](http://i1319.photobucket.com/albums/t670/d3nso/20130815_1820071_zpsab235541.jpg)
![AEU86 AE86 - d3nso's little AE86 N2 build [Image: AEU86 AE86 - d3nso's little AE86 N2 build]](http://i1319.photobucket.com/albums/t670/d3nso/AE86/IMG_20170308_200506_zpsrpprozvy.jpg)
![AEU86 AE86 - d3nso's little AE86 N2 build [Image: AEU86 AE86 - d3nso's little AE86 N2 build]](http://i1319.photobucket.com/albums/t670/d3nso/AE86/IMG_20170408_174442_zpspnjn4ci2.jpg)
![AEU86 AE86 - d3nso's little AE86 N2 build [Image: AEU86 AE86 - d3nso's little AE86 N2 build]](http://i1319.photobucket.com/albums/t670/d3nso/AE86/IMG_20170408_174452_zpstn11hhoc.jpg)
![AEU86 AE86 - d3nso's little AE86 N2 build [Image: AEU86 AE86 - d3nso's little AE86 N2 build]](http://i1319.photobucket.com/albums/t670/d3nso/AE86/IMG_20170408_174623_zpsptsr6jul.jpg)
![AEU86 AE86 - d3nso's little AE86 N2 build [Image: AEU86 AE86 - d3nso's little AE86 N2 build]](http://i1319.photobucket.com/albums/t670/d3nso/AE86/IMG_20170408_174656_zps0mbjr50q.jpg)
![AEU86 AE86 - d3nso's little AE86 N2 build [Image: AEU86 AE86 - d3nso's little AE86 N2 build]](http://i1319.photobucket.com/albums/t670/d3nso/AE86/IMG_20170408_174701_zpsbqfypnbs.jpg)
![AEU86 AE86 - d3nso's little AE86 N2 build [Image: AEU86 AE86 - d3nso's little AE86 N2 build]](https://www.aeu86.org/sticker-banner-468.gif)
